Question about Tomtom GO 700 GPS Receiver
The device does not respond, does not turn on
I left the gps in the car in the cold for 8 hours. when i wanted to turn it on, it did not respond. there is only the welcome screen.
  • 85 Answers
Dont leave sat nav in car as it kills battery,try removing memo card if installed hold in reset button few seconds ,reinstall card if fitted and try boot up
Posted on Jan 08, 2009
I just purchased this product and it will not turn on with being plugged in. Also, no reset button
When the battery is fully charged it should turn on without being plugged in. Charge it for 4 hours on the car charger or for 8 hours through a computer. There's no reset button on most garmin satnavs. To reset it you press the bottom right corner, when the satnav is turned off, and press and hold the on button until is asks you if you really want to reset it. It takes about 20 seconds to ask you.
Jun 11, 2011 | Garmin nuvi 255W GPS Receiver
My garmin 205 turns off when t start to run but will for 13 hours just sitting there.
If your Nuvi won't turn on, it's possible that it's locked up. Try using the reset button as follows.
Nuvi 3xx & 6xx Series: The reset is located on the rear of the unit, underneath the antenna. Press and hold it for at least 8 seconds and then release.
Nuvi 7xx Series: Slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Nuvi 2xx & 2xxW: There are (2) different versions of this series.
Some will have the reset on the bottom, where the decal is. There will be a small flap labeled "reset".
On newer units, slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Oct 23, 2010 | Garmin Forerunner 205 GPS Receiver
Wont turn on
How do you turn it on ? Power button needs be pushed left to turn on, right is locking device.
If this does not work, check charging the device. Plug it in charger for 4 hours.
If all this is OK, you should reset device
Hold power button on left for 8 seconds. Release, then restart normally.
Sep 26, 2010 | Garmin nuvi 750 GPS Receiver
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on
If this fails to solve the problem, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
The touch screen on my magellan 5310 no longer responds to anything. It is 3 months old and barely used. I used it for 3 days driving to Florida. The next trip it stopped responding to touch sfter 2...
Hi gmarleau
an reset or an update might fix it, but if it doesnt, its still under warranty!
turn on your 5310 and locate the reset on the bottom left of your unit (small pinhole) use a paperclip to insert and depress the reset switch.
if that fails and you want to try an update, you can get the 4.72 update HERE you have to sign in and register before they will let you download anything.
to send it in for warranty repair or replacement call the number listed below.
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
bill
Nov 20, 2009 | Magellan Maestro 5310 Car GPS Receiver
I used my Garmin 760 all morning, left it in the car, and 4 hours later it did not work. I have had this since December and have never had this problem. It will not turn on.
hey there, I am not sure where you are located or what your outside temperature is but unfortunately the GPS unit that is made for a car is not made to be left in a car. You cannot leave it in cold or hot conditions or it will fail. There should be a temperature rating in the instruction manual somewhere to check. If this is not the case let me know, if it is, believe me you are not the first to leave a car accessory (GPS) in a car when it is not (should be) designed to be.
seth
Aug 02, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
The gps does not respond
A friend of mine had a similar problem it was the battery and it was killed took it back to shop and got a new one it was 4 months old.
Jan 08, 2009 | Tomtom GO 700 GPS Receiver
My time is pm and I want to change it to am
Tap screen, Change Preferences, Right Arrow to side 8 of 8,
tap Set Clock.
Adjust time settings... You need to tap hours 12 hours ahead or backwards to change pm -> am.
Mar 10, 2008 | Tomtom ONE GPS Receiver
Will not come on.
GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Tomtom GO 700 GPS Receiver Logo
103 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
