Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
Cannot power up yet all the fuses are okay - Panasonic Videoprojector PT-LM1E Multimedia Projector
  • 22 Answers
Your lamp ballast could be bad. If you have had it unplugged for a while, plug it in for about an hour before turning on, then reset your lamp timer.
Posted on Jan 09, 2009
50 Emerson LED LF501EM4F will not power on. No standby light.
Hi. Please check that the power cable is okay. Then, open tv and confirm that the fuse is okay. If fuse is okay then power board has an issue. It could be a capacitor,resistor,diode or ic. If fuse is blown, do not replace it before the tv is checked to prevent more damage. To know whether tv has a short circuit or power board has a fault, Get a 60 watt filament bulb and remove damaged fuse then solder some wires to the two bulb termini and solder the two ends at the two points on the fuse and power the tv. If the bulb come on and goes off then the power board is okay because this signifies that a circuit is complete. If the bulb goes on and does not go off then it means that there is an issue and the circuit is not complete. Under state 1 replace fuse and power your tv and it has to go on. Under state 2 please have a qualified technician check the power board.
Nov 15, 2016 | Emerson Televison & Video
My sony entertainment center model #dx375will not power up after sitting idle for months
Hi. Check the power cable to make sure it is okay. Try to power from different points. If this does not work, see if the internal fuse is okay. If the fuse is okay then means the power board has an issue. In essence, you can not know what the fault is unless power comes on.
Nov 06, 2016 | Sony DAV-DX375 System
My radio has no power at all
check the fuse in the fuse box
if that is okay check the in line fuse in the radio's waring harness.
If that is okay check the internal fuse
Jul 16, 2015 | 2006 Ford Fusion
Truck wont start
replace battery cables could have bad ground cable.if see dash lights on when turn ignition to on position.check starter fuse or relay or remove starter check for faulty starter solenoid or starter.if starter okay and fuse starter relay okay ignition fuse and switch okay see dash lights could have problem in the theft security system need have vechicle code scan see if theft security fault code show up.
Jan 28, 2013 | 1998 Chevrolet Chevrolet silverado
Yesterday my wife had the car battery replaced by the RAC and her Pioneer DEH-2050MPG unit doesn't work now and gets no power to it. I checked the car fuse for the radio and it appears to be okay
Check all of your fuses. There are probably two fuse boxes in the vehicle. There may be a fuse either inline or on the back of the radio.
Dec 25, 2012 | Car Audio & Video
2009 Harley ultra classic - audio system won't power up- checked all fuses all okay, all other electrical system components work
Check to make sure the connectors in the back of the radio are not loose. If this isn't the problem, the radio may have to be sent in for repair.
Jul 30, 2012 | 2009 Harley Davidson FLHTCU Ultra Classic...
99 ford contour A/C fuse burnt in socket...need to find the 2 wires to bypass with inline fuse, driver side fuse panel? help?
Somthing doesnt sound right here, someone must of installed a bigger fuse than whats called for, i would have the system checked to see why its drawing so much amperage, you will need to remove the fusebox and chase that wire, you want the ac side of the wire not the hot side, if you are reusing the power wire then okay chase them both, but you will need to chase them into box, use an ohm meter with a continuty test on it to locate the right wires,okay i just found a wiring diagram, the fuse is on the driverside fuse box , okay the wire you are looking for is violet/purple and this is for fuse location #37 which holds a 30amp fuse,the other wire is a power wire and should be red,note there are a lot of hot red wire so try to use the same one by chasing it.
Mar 23, 2011 | 1999 Ford Contour
Air conditioner or heater air wont blow
check hvac fuse. if fuse is okay.check to see if blower motor getting power if yes blower motor faulty.if no blower motor control switch is bad if fuse and relay okay.
May 25, 2010 | 2005 Land Rover LR3
Radio has no power fuse okay
There may be two fuses in the 12V line to your radio; generally the 'accessory' fuse in the fuse box and a second one in the dedicated 12V line to the radio and this one will be under the dashboard.
Mar 13, 2010 | 2008 Pontiac G6
Power failure
Usually just random failure of the 250mA fuse (F1) which is on the power input circuit board under the platter.
Sep 29, 2009 | Technics SL-1200MK2 Turntable
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
