Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG TROMM washing machine can't open door
Because water supply stopped, machine stopped as well, now can't open it, it's full of water and clothes and machine does not react to any new program, makes strange noise
  • LG Master
  • 19,396 Answers
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Posted on Jan 08, 2009
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
STARTING PROBLEM OF FRONTLOAD WASHINGMACHINE
If the error code is DE, then you need the door lock assembly.
I will need the full model number to find the right part number.
Mar 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Musty/Mildew smelling clothes...
lg has a known problem with smelly mildew cloths. If you call LG they will tell you its not there problem. Cheapest solution is to wash door gasket with some clorox and then betwen washes leave door open. On the washing supply shelves there is a product you put in the washing machine run a wash without cloths and it does the same thing except it costs $7.If you bought it a t Lowes go back and ***** to store manager my friend did exactly that and got the machinje replaced
Sep 30, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Feb 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front load washer machine
Try using www.affresh.com, in the wash using hot water. If your unit has a tub clean cycle use it. Leave the door open after using the unit to allow it to breath and wipe down the gasket. Use HE detergent and you don't have to use too much. That goes for the fabric softener as well.
Sgt 48
Jun 07, 2008 | Washing Machines
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Lg tromm wm2277wh washing machine
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Oct 13, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
421 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
