Hi My Tricity Bendix AW1560W won't fill with water. It makes a low sort of clunk when you turn it on. The water supply is fine, the checked the filter and inflow and it all sems ok. What else can we check?! Many thanks
  • Lady-of-glen Apr 21, 2009
    I have the same problem with my tricity bendix washine machine. I've got some one coming to look at it. I'll post what's wrong when I find out.
The pump on my machine needed replaceed. Lickily I found a guy in the yellow pages who lived in the area and did a free call out and free estimate. He also only charged 50 ppound for the new pump and fitting. If you live in South Wales then the number to phone is 0800 335 7515. very nice guy.
Posted on Apr 23, 2009
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Where is the filter on a AW1560W washing machine
There is a small 4 inch square door on the bottom right of the front of the machine. Press the right hand side of the door and it will pop open. Pull out the small drain hose, drain off any excess water, unscrew the corcular filter cover to extract it. Instructions and pictures can be found on page 17 of your user manual. If you do not have a manual, you can download one here:
http://www.usersmanualguide.com/tricity_bendix/washing_machine/aw850w
Please rate this solution
Jul 21, 2011 | Tricity Bendix AW850W Front Load Washer
Tricity bendix dh101
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
If you enter model number here , you can find parts and diagrams.
Nov 03, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Water just keeps running /won't fill
this is an easy one. the waste pipe is two low!!
Oct 20, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
