How can access the BIOS interrupt using c language
Please specify the code for it
I need drivers for Sony laptop VGN-NS 150D for O/S WIN XP
Posted on Jan 08, 2009
Error 3600 en kyocera km1820
Is it a C code?
The service manual only shows one code 3600:
U03600:
Confidential polling reception was interrupted because of a mismatch in specified confidential box No. Or, an interoffice subaddress-based bulletin board reception was interrupted because of a mismatch in the specified subaddress confidential box number.
This regards fax system (k)
Jan 28, 2013 | Kyocera Copystar CS-1820 Black and White...
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Please give us a sample code of payroll system using time-in and time-out.
You are looking for sample code. It would have been good in case you could specify which language you are using. However i'm copying the link for the some the sample codes that you can see.
http://www.sourcecodeonline.com/list?q=time_in_time_out_payroll_system_visual_basic
Hope the same is helpful. In case not , reply back with the language you are using so that i can make the same for you .
Thanks
Proton
Mar 31, 2011 | Computers & Internet
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Feb 18, 2010 | IBM ThinkPad T42 Notebook
I wanna change the japanese version to english
access your bios set up and change the language. If you don't know how to access your bios, look the screen when the system is booting up or use the manual. I hope they allow other languages in the bios. Just change the language cuz if u try experiments u will have bad surprises....this place is where it's configure how everything work on your computer!!!!
Sep 18, 2009 | Fujitsu Computers & Internet
Lenovo thinkpad R51e , when i power on the laptop it show error code 271
You need to set time and date in BIOS.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Change my system setup to english language
upon bootup, look at options to write to BIOS. Typically, can be any key from F1 to F12. You have a small window in which to stroke the key in which to access BIOS. Once within BIOS, you may change your language to English. Also, once in BIOS, change your settings to depict read format in this order:
CDROM, HHD
Should you have a floppy, enable that as well and place that prior to the CDROM.
Good luck.
Oct 15, 2008 | Computers & Internet
Matrox G400/450 installed and Getting error code 12
Is this in addition to or inplace of the existing HD? Do U check the Bios to insure it was reconized by the pc? There should be a cd to boot up on that will preset (fdisk) the HD, did U run that?
Jun 18, 2008 | Computers & Internet
Open Questions:
Support - Storage Solutions - Toshiba'call +1888784-9316 Toshiba is known to be a world class innovator and high technology product leader globally with its 24x7 major subsidiaries and affiliates worldwide. Toshiba launched their first laptop computer way back in 1985 and since then they have managed a record worldwide cumulative shipment of more than 100 million Laptops at Financial Year 2010. Toshiba laptops are sought after because of its quality and superior performance. Regardless of the superior features and all the convenience, you can easily be denied support by Dell Support for any issues that could mess up with your critical data backup, recovery and security. OS crashes are one of the major reason for critical data loss. The other contributors for data loss are accidental data deletion, Virus Attack and natural disasters. Unless, you have an updated backup, you can very well assume that you may have to part away from your precious data. DataAlign takes control of such situations and helps you Toshiba Support backup your data and restore it as per your requirements. DataAlign lets you select backup schedules and it then runs automatically as per the configured schedules. With Automatic Backup protection, DataAlign gives you peace of mind when it comes to data backup and restore. DataAlign's affordable TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus computer. And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any Toshiba Customer service issue that you may face with your TOSHIBA product. Toshiba Help Desk Number 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 26, 2018 | Dell Computers & Internet
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
