Question about Evenflo Embrace
Infant Rear facing car seat
I have lost the manual to my childs car seat. Could you please tell me how I lower the straps for the 5-Point harness? Thank You.
  • Anonymous Jul 13, 2008
    I Have Lost My Manual How Do I Adjust The Straps On The Infant Rear Facing Car Seat For a 3 Week Old
    Problem Solver:
  • 5 Answers
1. Depress the harness adjustment button
under the seat flap. Pull the shoulder
straps out to loosen the harness.
2. Behind seat, remove the ends of the two
shoulder straps from the metal junction
plate.
3. From front, pull straps through the
harness slots and then reinsert them
through the appropriate slots.
4. Behind seat, push both shoulder
straps UNDER owner’s manual pocket
and out the bottom.
5. Reassemble the strap ends onto the
metal junction plate.
Page 28-31
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Good Luck and be safe!!!
Posted on Nov 20, 2007
  • 30 Answers
ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
Posted on Jun 30, 2007
What does cosco scenera model 22216-llp
You should see a harness strap over each shoulder that goes though the shell, behind the seat, and connects to a metal splitter plate.
The front of the harnesses (2) extend down though the buckle tongues then into the hip area of the seat.
There is a crotch strap that comes out of the shell where the child\'s crotch is. The buckle is attached to this strap.
There will be a LATCH (Lower Anchors and Tethers for Children) strap that goes through one of two belt paths. If used, this strap must go though the proper belt path.
Finally, there is a top tether strap the comes from the back of the seat - near the top - that will attach to the tether anchor in your car (see your car owner\'s manual)
My suggestion to you is to purchase a new seat. The protection of your child is most important.
Jul 10, 2014 | Baby Gear
Making car seat harness larger for child/evenflow discovery 5
You can download this PDF instructional manual for the Evenflo Discovery car seat: https://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHUQFjAH&url=https%3A%2F%2Fplweb.evenflo.com%2FShowDocument.aspx%3FManualID%3D583&ei=A8UtUbW5AY_Z4QSCjoDoCA&usg=AFQjCNFj1O1EuRQVLmKwgOLTJsL6yoeOTQ&bvm=bv.42965579,d.bGE
You can also read this article on how to adjust the harness straps on an Evenflo car carrier: http://www.ehow.com/how_6391052_adjust-evenflo-car-carrier-straps.html
Aug 03, 2012 | Baby Gear
Hi there. I have a smart trike classic.I would like to change it to 15month+ and have remved the sunshade and backing. However is there a seatbelt for it at this stage I cannot work out how to take the...
  • For 15 months you remover the headrest.
  • The safety rails come off.
  • As for the harness - there is a single strap that will go around your child's lower abdomen and wrap behind the seat. This strap weaves into a hole on a strap that runs from the front of the strap around your child's waist, under the seat itself and up to the waist strap in the rear. So basically the way the harness is set up for 10+ months old your gonna remove the over the should part of the harness and run the two buckles in front behind the seat.
Regards, Tony
Apr 27, 2011 | Toys
The car seat for baby has very short harness straps. Where can I order an extantion for harness straps?
There is no such thing as an extension for a carseat harness - it would be unsafe. The carseat harness has ample length for your child but will require extending as per the user manual to fit around the child safely.
Sep 28, 2010 | Maxi-Cosi Priori
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Can't put back together
Do you have a company name for this product? Graco, Cosco? If you do I can look up an online manual for you as there is most likely a diagram to make my description easier for you to visualize. At any rate you need to insert 2 of the straps (the ones with the pieces to snap into the buckle at the **** ) through the back side (aline your child with the slots to ensure correct placement. You want the belt to come out just above the shoulder) DId you take this completely apart to wash? If so you will need to slip on the chest buckle pieces as well. Hope this helps. I can help better if you are able to get back with the company name so I can get the manual for you. :)
Aug 16, 2008 | Baby Gear
Manual for a car seat
First set the harness together at the chest clip and the **** buckle. Then slide each shoulder strap through at the best height for your child. For a forward facing seat , it should be at or above the shoulders. Once both shoulders are passed through, there is a Tshapped metal flat piece, each belt slides onto that. That is 2 of the 4 ends of the straps squared away. The bottom 2 , you slide through the holes in the car seat, through the holes in the shell of the seat, and then pull to ensure they are in tight. Thank you!
Jun 15, 2008 | Graco Baby Gear
Switch to booster seat
We have two of these for our vehicles, Its pretty simple once you do it. THere is one metal bar (rod) underneath the base. You need to bend the plastic tab to the side in order to slide the rod out of the base. Once the rod is removed the base comes free. After removing the 5 point harness straps (and cleaning all the crumbs accumulated from underneath), you're ready to go.
When set in pace in the car, just the seatbelt hold the child in place.
Hope that helps
Jan 11, 2008 | Cosco Alpha Omega Elite - Hammer Print
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Evenflo Embrace Logo
575 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
