Question about Samsung HT-WX70 Theater System
Unit shuts itself off after 10 -15 minutes
After 10 - 15 minutes protection scrolls across screen then goodbye appears and finally unit shuts itself off.
  • Anonymous Jan 11, 2009
    David, The same problem occured, when I talked to samsung they put me thru all the stupid owner tricks, then abruptly told me they couldn't help at this time, gave me a number and I never heard from them again. Other than not working after 15 to 20 minutes it's a great unit. Thanks samsung for all your customer assistance.
  • oldgrunt Mar 15, 2009
    My unit also turns off for no reason after a few minuets. Unit is 2 months old.
    I wish I did not buy the 46" LCD TV simply because it's Samsung.
    They gave me a number and told me they would get in touch with me in 24.48 hours. It's been 2 weeks. Still nothing. I wanted to see how long it would take.
  • Samsung Master
  • 19,396 Answers
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Film 2 SD Shuts Down
I have a question to ask you( you idiot) not a solution . Paul
Nov 05, 2011 | ION Audio Film2SD Film Scanner
I get a PROTECTION message on my system. What is
the unit goes into auto protection mode whenever there is a shorted pair of speaker wires. check all the connections carefully to make sure no wires are touching any others on the back of the main unit and at each speaker
Nov 03, 2009 | Samsung HT-TX72 Theater System
Fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jul 04, 2009 | Samsung HT-Z310T Theater System
The system goes into Sleep mode every 5 minutes and just before going into the sleep mode,''protection Error'' flases on the screen
Unfortunately, the unit is not going into "Sleep mode".
The PROTECTION error actually means that the unit is overheating.
The unit shuts itself off to avoid further damage.
Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it.
If not, call 1-800-7267864 and let them set up a repair order for the unit.
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Surround sound shuts off like the sleep timer is on
power amp problem are you familier with electronics?
then we can do more.
shall we?????
Jan 03, 2009 | Samsung HT-WX70 Theater System
Hx-d7
You have a short in the internal power of this unit. It is going into protect and shutting itself off to keep it from damaging anymore of the internal electronics. Very likely a voltage regulator has gone bad or a power capacitor has gone bad. You will not be able to repair this yourself unless you are skilled in electronic repair. I would suggest contacting the manu and seeing if they have a authorized repair shop in your area. If not ask around and see who is a reputable repair shop in your area.
Feb 08, 2008 | JVC HX-D7 Shelf System
Protection
Protection means the unit is detecting a short somewhere. Disconnect speakers and components and attempt to power on the unit again. If it will power on with nothing connected, repeat the process (turn off, connect something, then power on) until you find the bad component or speaker.
Jan 24, 2008 | Samsung HT-DB120 System
XL-MP60 Micro Component System
Email answer I got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Nov 03, 2007 | Sharp XL-MP60 Shelf System
Samsung HT-WX70 Theater System Logo
405 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
