Question about Olympus Camedia C-350 Digital Camera
New data card will not format
Bought a new data card and it will not format in the camera. Keeps statnig error.
Please help
  • 88 Answers
Possible you have a bad card. Try getting a new card and formatting it. The cards that come with the cameras are cheaply made and usually don't last very long anyways.
Posted on Jan 08, 2009
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
I have bought new camera, just tried it today and keeps saying error code 99? turn it off and back on and remove battery and reinstall, tried all of this and it keeps saying the same?
Error 99 is a catch basin for a number of problems I'm going to assume that because this is a new camera that you didn't format the memory card. Formatting a memory card makes it function perfectly with the camera it's being used in. Also after pictures have been downloaded to the computer you need to format the memory card, cleaning all the old pictures off the card and giving you a fresh clean medium to use to put new pictures on. You will see also that there is this little handy garbage can icon and this is or should be used only when you find you need more space on the card when you are shooting and not the way to clear the card. The memory card should always be formatted in the camera.
Dec 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
My camera shows an on-screen message says: "Format Error". I formatted the memory card but the problem still there. what to do? should I replace the camera built-in software?
First of all u try to format card in another camera. If problem still remaining, u will change ur card. Normally this problem by the card.
Mar 16, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
Panasonic Lumix will not read memory card.
try formatting your cd card in your Fz. If it keeps telling you memory error, try using it in windows, put data on it, to see wether it can hold them and read them too.
Happeded to me once too, format did the job. Just format it in the camera, not your pc.
Vladimir
Jul 01, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Problem with new memory card
I read an article about the same problem.....
Ill tell you the information about it.....
There are few situations when you find that your memory card is not functioning as expected and instead of data, you are getting few error messages:
· “CARD ERROR”
· “ Memory Card Error”
· “Card Not Initialized”
· “Read Error”
Display of either error message forces the user to think of solution as the affected memory card may be the house of the relevant digital data including photos, videos and audios.
Most of such error messages are curable through formatting the card.
As you said you have tried this already but no success......
So your card is suffering from the problem that the card is corrupt harshly.
This is the worst defect in the memory cards......So better get it changed..
The memory card corruption reveals that the data will remain inaccessible as formatting has failed to cure the issue. So the best deal would be to have photo recovery software. Photo recovery is also required in case of formatting success.
Picture recovery is quite practical through photo recovery software which benefits the users through their scanning ability and power to address each specific case of photo loss.........
Hope my info helps you.........
Thanx
Oct 07, 2008 | Fuji FinePix A605 Digital Camera
Cyber-shot DSC-W35 format error c:13:01
Software for Memory error correction is available on charge basis to get data/ pictures.
Jul 29, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Olympud d-560 zoom
Check your manual the card, any card needs to be formatted in the camerer
Jul 22, 2008 | Olympus Camedia C-350 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
