Question about Acer AL1916B 19" LCD Monitor
Menu randomly pops up while pushing no buttons....
For some reason, the menu to change monitor settings will randomly pop up and block my screen for 30 or so seconds at a time. Sometimes this will happen every 3 or 4 minutes, but not usually that often. Hitting the buttons on the monitor will not make the menu go off and I'm actually not even sure if I am able to change the settings for the monitor. Also, related and almost just as annoying, when I try to turn off my monitor, say while the computer is still on because I won't be using it for a bit, hitting the power button will not turn off the monitor but instead bring up the settings menu. Nothing will make menu go off and eventually get fed up with trying to turn off my monitor. Sometimes hitting the power button 15 or more times will eventually turn it off, but it's a major pain. Any help would certainly be appreciated. I believe I still have time on my warranty, so if that seems like the best option than so be it. I figured that I would try here first. Thanks...
  • Anonymous Dec 10, 2007
    i have the same trouble with my monitor i can't turn it off
    mine is a samsung 731n
    President:
  • Acer Master
  • 1,314 Answers
It sounds like an issue with the power button board and I would certainly make use of the warranty option.
Posted on Jun 10, 2007
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Gemstar perjection screen theater tv after about 10 or 20 min the menu screen pops up and then randomly selecting options repeatedly non stop, how to fix and around how much will it cost?
If the menu pops up at random it likely is the menu button on the set being bad--not the plastic button but the switch under it.
You in USA---? I know two people in St. Louis named Nikki and nick.
what kind of set and what model number?
May 20, 2012 | Televison & Video
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
Menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Jun 01, 2009 | Dell E157FP Monitor
Menu box keeps popping up on screen
Same problem here. I've had this monitor almost two years with no problem until this morning when it started flashing the menu screen and nothing I do will make it stop. Oh well, it was only a hundred dollars. I guess this is emachine's way of saying, "you got your money's worth, now throw this piece of junk away and get another", lol. And therein lies the solution! :)
Jan 13, 2009 | Computers & Internet
Menu Screen
so sorry, not a solution but the same thing is happening to me. gateway emachine model LE1799
Aug 17, 2008 | Gateway FPD1975 19" LCD Monitor
Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
Mar 16, 2008 | Sony SDM-HS95P/S (Silver) 19" LCD Monitor
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Acer AL1916B 19" LCD Monitor Logo
415 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
