PC Chips P23G Motherboard Logo
Posted on Jan 08, 2009
Changing from ddr2 533 MHz to PC6400 800MHz Memory
Can I change from 533 MHz to 800 MHz, on a P23G V1?
  • Anonymous Jan 18, 2009
    help me
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
33791
Points
96
In general, slightly higher freq memory, as far as it is the same type and physical size should be no problem as it will be underused.
  • Anonymous Jan 09, 2009
    Can you please rate my response. Thank you
Can the maxon SL55 V2 programmed for 144 -146 Mhz
GENERAL Performance Specifications R&TTE Directive 1999/5/EC Band VHF (V1): 136-162 MHz VHF (V2): 146-174 MHz UHF (U1): 400-430 MHz UHF (U2): 440-470 MHz Number of Channels 16 Channel Spacing 12.5kHz, 20kHz, 25kHz (Programmable per channel)
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
1helpful
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
3answers
I have bought a kingston DDR2 ram memory (800 mhz, PC6400, 2GB = 1x2GB) and my motherboard recognizes only a half of it (1024). What can I do to fix it?
If its one RAM den be sure it is 2 GB if 2 RAMS den please see that have you fixed the RAM properly..Try taking out the RAM and clean the lower portion with a clean Rubber/Eraser and dne fix it back properly..
BIOS only seeing half of just-installed 2x1GB DDR2 RAM
did u check the old RAM...do they also show only half ?
may be ur new RAMs are not compatible with ur MB
what's the speed of ur new RAMs....400 or 533 ?
3helpful
2answers
Maxing memory speed, GB or MHz more important?
I don't think a difference of 133MHz of memory speed will make a difference in your gaming performance either way. Also, you won't be able to use more than 3.5GB of memory if you don't have a 64-bit operating system. Finally, it'll be a rare person who actually notices a difference in using 8GB vs 4GB of RAM. So, in conclusion, just buy 4GB of 800MHz RAM and spend your money and your time on a good graphics card, if gaming performance is your main concern. If you have any further questions, contact me through http://www.inovagent.com.
1helpful
Its processor is only 800 mhz, can i upgrade it into a more higher mhz?
insteading of changing the motherbard for making it fast try upgrading the memory cards it add extra memory stcks in the computer to make it faster...
Laptop memory
DDR2 800 MHz (PC2 6400)
the best
and 2gb or 4gb is up to you
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
4answers
Pentium D 1066 extreme processor install.
What version is your board. PC Chips P23G V1.0 up to V3.0 ?
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
