Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Dial gets stuck on Frigidaire FDB740RCS0
The problem is that the dial gets stuck, and has to be manually advanced, in the same 2 positions every cycle. The first stoppage occurs very near the midpoint between Light Wash and Drying on the dial. According to the cycle chart it would appear that this falls between the 2nd wash and 3rd rinse or about 25mins. into a Light wash. The second stoppage occurs right on or just before the drying cycle starts or, according to the cycle chart, about 47mins. into a Light wash. My parents have the same dishwasher, so I tried switching the control panel, only to find the exact same problem at the exact same points. So I don't think its the timer, and don't know what else it might be. If you could give me any guidance I would greatly appreciate it. Thanks in Advance,
John
  • johnjo2e Dec 22, 2009
    problem solved, it was the thermostat burnt out.
5 Suggested Answers
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
Posted on Jun 09, 2009
SOURCE: Dishwasher gets stuck on the rinse cycle right
Try turning off the high temp wash. I had a similar problem and found that the thermostat is bad. Turning off the high temp wash bypasses the high temp thermostat.
Posted on Jun 23, 2009
heatman101
  • 43501 Answers
SOURCE: Several people have posted this
I know that you are going to think that this is dumb... but the only thing that it can really be is the timer....
http://www.partselect.com/PartDetail.aspx?Inventory=735039&SourceCode=5&ModelNum=fdp750rc
I think that the extra tripper that it needs to activate with the heat is stalling it...
heatman101
Posted on Dec 29, 2010
SOURCE: main control timer hangs up
Water is not spraying through top spout and its making a weird noise...
Posted on Apr 13, 2011
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
Dial does not advance through all parts of the wash cycle
Replace the timer of the unit. With the mothel number that is behind the timer, you can order it. The timer location is at the back of the unit. Remouve the cover at the back of the control panel, then look for the part that look like a smal motor at the back of the knob. remouve the knob and the small screws, then desconect the wires plugs, do not cut any wire. then instal the new one.
Aug 05, 2009 | Frigidaire Affinity ATF6000F Front Load...
Whirlpool mo 110753790 It gets stuck in the wash cycle & will not move unless you move the dial. This happens while the heat light is on & light will not go off which causes the dial to be stuck....
Timer behind dial is defective if it will not advance on it's own. Either continue to advance past the defective section of replace it.
Jul 06, 2009 | Dishwashers
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
Dishwasher stalls
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Apr 07, 2009 | Bosch SHU4006 Dishwasher
Frigidaire gallery washer
Do you mean that after it fills up with water you have to advance the dial for it to start working?if that is so Check the water level switch.Otherwise you may have aproblem with the timer.
Regards
Please rate this solution
Sep 24, 2008 | Frigidaire GLTR1670A Front Load Washer
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Machine won't run through cycles automaticly
Sounds to me it might be a thermal pause, if your unit is running and then is required to heat up at a certain point and reach a certain tempurature before it advances, the heater is probably not coming on. The unit will therefore not advance.
Sgt 48
Jun 02, 2008 | Malber P21 Front Load Washer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
73 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
