Sony tv kv t25 the flybeck transistor gets very hot
Hello
after replacing the hot I notice that the hot gets very very hot and blows after about a day of working
what can be the problem.
thank you
david
  • shopy Jan 11, 2009
    thank you for your help
    ther is no dvr601,602,603 in this TV
    can you help me to find a schematic diagram for this TV
    thank you
    david
    Champion:
  • 240 Answers
Replace the hot and the flyback and dvr601 602 and 603 make shure your yousing heat sink on the hot.
Posted on Jan 09, 2009
KV-DZ29M61 crt green light blinks 12 times hot over heet just 2minites
Hello
Its HOT [Horizontal Output Transofrmer] section circuits has the trouble. There are two possibilities for this fault. The first one is shorted HOT itsef. It can be replaced; and can be bought from most of the electronic sparepart shops at your town. It will have a number printed on it, and should benoted. Must replace with same number. The second fault is with leakey Horizonal Output Transsistor. This is the transistor that drives the HOT said above. Just repalce this transistor first. After replacing it, just switch ON the set for a few seconds; say 5 seconds or so, and check the heat of the replaced transitor. If it overheats within this time period, HOT is defective and should be replaced. OK.
Jul 18, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony kv-g21m1 the h-out always busted.what is the best solution
Hi Nestor,
I've suspect that your Flyback Transformer is shorted this is based on my experienced on a lot of Sony tv, that's the common reason why H-out transistor keeps blowing. Before replacing the FBT you should re-solder around it, check the B+ for high voltage. Check the capacitor around.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 17, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Sony trinitron not working properly after FBT replaced...
the capacitors in horizontal circuit near the FBT . probably the HOT is damaged again due to the capacitors problem.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony FD Trinitron Wega Model KV-24FS 100 TV. Good morning from Arizona. The set is connected to Direct TV, and I use that remote, except when watching DVDs. A few days ago, the screen went blank, and the...
The 2X blink indicates that either the Horizontal output transistor is shorted, or the RGB amp is shorted (on the CV board).
The Horizontal output is probably the cause, and as a general rule, the flyback should be replaced along with the H-Out transistor. Good news is that Sony is pretty good about having parts in stock. In fact, a lot of times they will have the A board with all the parts on it for only a few bucks more than just the flyback, so you basically get a new TV (electronics-wise).
Any decent repair shop should help get the parts/do the repair for you if you don't have the electronic experience.
Hope this helps you...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony 27s42 broke the horizontal output transistor
Be sure to make sure the connection on the horizontal driver transformer are soldered good. check caps around HOT
May 23, 2008 | Sony KV-27S42 27" TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
For Sony KV-1415WR problem
Hiii...
First :
what chassis your tv set have ?
#2 : Where exactly the location of D608 ?
#3 : How may time the LED Blinking ? like we all know Sony have selft diagnostic with it ?!
I hope hear from you soon...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Oct 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
