Question about Nokia 6080 Cellular Phone
Automatically Press Keys
While talking keys are automatically pree without touching my fingure or any part of the body.
  • ravishekhars Jan 12, 2009
    This is a general problem in Nokia 6080
    Sergeant:
  • 431 Answers
You have activated automatic key pad lock in u r phone disable it. you can find in settings menu
Posted on Jan 08, 2009
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Doors lock or unlock without pressing button, also while driving this will happen.
all newer cars lock automatically when you take them out of park, and when you park and take the keys out of the ignition they unlock automatically also, if thats what your talking about
Apr 12, 2011 | Kia Sportage Cars & Trucks
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ??...
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Mar 24, 2011 | Compaq Computers & Internet
Hi how can i reformat my phone?pls help me
Turns off the phone
Press simultaneously on the green/talk, 3 and* keys and hold the 3 keys.
Turn on your phone
Wait for the onscreen Format message then can release the three keys
This method may also work for Nokia phones that won't turn on.
Note that before making a reset on Nokia's latest phone
using the *#7370# or the 3 finger method, better make a backup, as you will automatically delete important data:
The license for pre-loaded contents (music, video, maps,etc..)
Mar 15, 2011 | Nokia 3230 Cellular Phone
My nokia x3 phone switches off automatically and when i start it again the screen blinks and again it switches off
Turns off the phone
Turn on your phone
The license for pre-loaded contents (music, video, maps,etc..) and pre-installed application (N-gage).
Feb 19, 2011 | Nokia X3 Cell Phone
Scanner on HP Laserjet 3055 won't run - message on screen reads "Scanner error 6, turn off then on". I have tried that several times without any new result. Any ideas?
Suggest you to perform a restore factory default settings on the printer.
To restore the factory-set defaults
On the all-in-one control panel, press Menu.
Use the < or the > button to select Service, and then press .
Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the all-in-one.
Jan 31, 2011 | HP LaserJet 3055 All-In-One Printer
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Automatically launching Windows Media Player without touching any of the QuickPlay keys. Want to disable the QuickPlay keys
You have a defective power/QP selection panel ( lower chin panel in front of the screen ) the actual cct board for touch selection has gone unservicable. Replacement required by auth Hp agent. Cost about $150A
Jul 30, 2009 | HP Pavilion dv2020us (882780664913) PC...
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
May i know?
turn off phone press *,3 and green diL KEY TOGETHER and turn on the phone without relasing hte keys prees the keys for 15 sec
Dec 06, 2007 | Cell Phones
Nokia 6080 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
