Question about LG LRBN20510WW Bottom Freezer Refrigerator
Ice collects in bottom of freezer
In LG 349SQF: Each day a layer of about 2-3 mm of ice collects in the bottom of the freezer compartment. If we leave it water flows onto floor. I suspect a fan is not working, but how do I access it? If not a fan, what is not working? Thanks John
  • 1 more comment
  • johnpc Jan 08, 2009
    I tested the seal by pulling a piece of paper through seal with door shut. It seemed to grip the paper all around, and looks ok with visual inspection. John
  • johnpc Jan 25, 2009
    Thanks very much. You're the man! (or woman?) Lots of ice, not fixed yet but I'm pretty sure you are correct
    John
  • johnpc Mar 14, 2009
    Just to complete the story, dous32 and ken 169 were spot on. The hole in the tray leads to a hose to a tray sitting on top of a heater unit. Make sure that the hose is not blocked and the tray is not overflowing.
Ive just actually just fixed our fridge freezer, pull all draws out take out two screw on back panel then remove then pull out the other panel with fan connected.
At the bottom under the coil you will see a shelf all this will be ice pour boiling water on ice and remove when it starts breaking up, you will then see a small hole on the left of the shelf pour hot water down every minute or so and if you have a syringe take excess water out before pouring more boiling water down after a while the hole will a clear up and the ice gone.
Posted on Mar 13, 2009
I had the same problem and has now been sorted ,u need to unscrew the white panel at back of freezer and then take out the panel behind that ,there is a tray that runs the width of the freezer with a drainhole at the left-hand side , u will probably find this has ice blocking the water that drains away from the fridge compartment , if u put boiling water and clear the ice u should find the problem resolved , 1 other option is 2 leave the fridge/freezer off for several days and it should defrost the problem , hope this helps
Posted on Jan 24, 2009
  • douglas Jan 25, 2009
    glad 2 help john , hope it sorts it 4 u !
    Scholar:
  • 67 Answers
Heya Johnpc,
The best way to check the fan is to open the door and to push in the door switch wait about thirty seconds and you should be able to hear the fan run. If you cannot hear the fan the chances are you should call domestic refrigeration tech out.
Another thing that also makes water gather in the freezer is the freezer door seal is old and not sealing correctly.
Is the freezer working all right still?
Posted on Jan 08, 2009
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
How does Auto defrost work and how long does it take
Hello there
A Look at the Defrosting System:
Modern refrigeration systems, whether industrial or household, feature a defrost system. A refrigeration system works by developing temperature below the water's freezing point. Long hours of continuous operation may lead to development of a layer of frost or ice around the freezer or the evaporator coil. This hinders the cooling capacity of the evaporator, making it difficult for the cooling effect to pass into the freezer. Without refrigerator defrosting, the layer of frost or ice leads to loss of cooling and lessening of performance coefficient of the refrigerator and higher electricity costs. There are various defrosting methods that your fridge can employ. Take a look at some of these defrosting methods.
Thermostat Defrosting:
Thermostat is a basic component in all modern refrigerators. The device allows you to set the freezer temperature that you want, depending on your requirement. Most often, a refrigerator with thermostat comes with a small plastic tray which can be found below the freezer compartment. This tray is where the excess water from your freezer goes to. The thermostat works by stopping the supply of power that is received by your compressor whenever the temperature that you have set has been reached.
The refrigeration unit stops producing the cooling effect whenever the thermostat stops, which happen several times a day. And during this stage, the frost or ice collected on the freezer starts to melt, with the resulting water collected in the tray. A small tube connects the tray to a small outlet usually located at the bottom back side of your refrigerator. A pan is installed there where the tube brings the water resulting from melted ice after defrosting.
Mar 01, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a Kenmore Model 795 refrigerator with an ice maker in the bottom drawer. We purchased the refrigerator in August of 2008 (currently November of 2010) and finally hooked up the ice maker last week. ...
The 795 model you make reference to only tells me that this is and LG bottom mount Refrigerator. There are several numbers missing from the model number. This is and example of a good part number: 79577253602 The filter for bottom mount LG units is usually in the upper RH side of the fresh food compartment. See this link: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810366-00001.png (item 611E)
The weak chlorine taste should fade unless the source is from your house water supply. Let the ice catch bin fill completely once and then dump everything in it. After that your ice should be normal. I think you may be noticing the taste you get from unused plastic tubing / water carrying parts. Just so you know if anyone used bleach to clean the freezer compartment the ice maker will catch any bleach water drips and pass that immediately into the ice. (Have very long customer warranty story with repeated in home visits about how I learned about people using bleach to clean freezer compartments!)
I digressed... just dump the ice collection bin after it is full one time and then check the ice taste on any ice after that. If you think maybe the taste is originating from the freezer compartment get a box of Arm & Hammer Baking Soda, cut off the top of the box and leave it in your refrigerator freezer for 6 weeks then toss it in the trash.
Another note no manufacturer will tell you is if you install a cheap in line water filter before the refrigerator water connection you can make the EXPENSIVE ONE on inside of the fresh food compartment last a very very long time.
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Refrigerators
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
My LG GR-349SQF freezer keeps getting ice in the very bottom
I believe your defrost condensate drain is blocked with ice or other foreign objects. Could you also double check the model number? Thanks, Sea breeze
Dec 29, 2009 | LG Refrigerators
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
LG LRBN20510WW Bottom Freezer Refrigerator Logo
327 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
