Washing Machines Logo
A
Anonymous Posted on Nov 19, 2012
Child lock in ifb washing machine
Hw to unlock the child lock
  • Harini Kumar
    Harini Kumar May 12, 2019
    It's showing disable child lock
  • Praful Sakore
    Praful Sakore Sep 02, 2019
    drain error apoear on display initially child lock
Boyd McSwain
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Sep 02, 2019
Boyd McSwain
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
69611
Points
106
Get akid and let them figure it out
John B
Level 2:
Habit-Forming:
  • Expert 111 Answers
  • Posted on Feb 06, 2019
John B
Expert
Level 2:
Habit-Forming:
Answers
111
Questions
0
Helped
56687
Points
352
Holding down the Start button for over 5 seconds turns the child lock
5 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Anonymous
  • Posted on Jul 25, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
LG help guy
  • 112 Answers
  • Posted on May 03, 2010
SOURCE: LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
prem mathew
  • 662 Answers
  • Posted on Jun 14, 2010
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Anonymous
  • Posted on Aug 22, 2010
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Hi, Our washing machine (IFB frond load senetor Aqua) is stuck at function disable Child lock and not not getting reset.it is stuck from yesterday
Look for two key pad buttons with a line with a smiling child face padlock symbol. Press and hold these two buttons until you see or here a response from the washing machine.
On a 8 Kg model, press and hold + and - Change buttons on the right of the LCD screen simultaneously for several seconds? That's the way to toggle the child lock on and off for this IFB model, https://www.amazon.in/IFB-Fully-Automatic-Senator-Aqua-SX/dp/B00LAXLN5C . On a 6Kg machine, https://www.amazon.in/IFB-Fully-Automatic-Diva-Aqua-SX/dp/B071G3B81W/ref=psdc_1380369031_t3_B00LAXLN5C , the appropriate buttons to hold are the Rapid Wash and No Cold. (These are on the right side of the control panel but to the left of the power button.)
Depending on the machine, the time to hold the buttons may be 3 seconds, 5 second or 10 seconds. You should see and hear some response. However, holding the key pad buttons for too long may re-enable the child lock.
I hope this helps. The child lock on most washers remains active even when the power is removed from the machine. This keeps the program from being activated when you clean the control panel or by a child who shouldn't access the machine. If the problem persists, I suggest checking for a problem with the keypad wiring or contacts.
My IFB washing machine displays CH, What is the error?
On some IFB washers, the CH indicates that the child lock (control panel lock) has been activated to avoid accidental washer use. On the IFB digital 5 KG washer, you can toggle the child lock on and off by pressing the Soak Option and Delay Start buttons simultaneously. These are the second and fourth button for the Optional settings above the LCD display on this model. Below the keys, there is a skeleton key symbol in the center of a line drawn between these two keys. You can see this information in the manual for this machine in the manual, http://www.ifbindustries.com/home_appliances/washing/manuals_new/DIGITAL_5_KGS.pdf . See page 9 (7 of the PDF) and page 13 (page 11 of the PDF).
I hope this helps. Please add a comment with your model number for information specific to your washer. If your washer uses a different set of keys to toggle the child lock on and off, you should look for the skeleton key symbol on the control panel housing. Any response to a follow-up comment may be delayed.
4answers
I have IFB washing machine it shows E7 error
Our experienced and skilled technicians are excellent to repair the IFB Washing machine, not only IFB; they will repair all reasonable brands of Washing machines. Our IFB Washing machine Service Center can offer the services within the Hyderabad and Secunderabad zones. We can provide Doorstep service with reasonable cost. call us at 9133356801 & 9133356802. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
ifb washing machine service center hyderabad-hgqlgbgiqjunocffergste0f-5-0.jpg
I can't get the child lock to deactivate on my Seimens S12-38 washing machine. Anybody got a solution?
Deactivate child lock siemens washing machine S12-74 ...
www.fixya.com/.../t15773878-deactivate_child_lock_siemens_washing
Jan 10, 2013 - deactivate child lock siemens washing machine S12-74 - SiemensWashing ... -Press and hold the option down touch button for 5 seconds or until you seethe magic message 'Child lock released'. ... I can`t deactivate the childlock ... I CANTDEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES.
How to unlock washing machine door for siemens s12.38 ...
www.fixya.com/.../t11409270-unlock_washing_machine_door_siemens
My ifb washing machine displays CH, please help, cannot start any other programme
CH means child lock is engaged. Here’s a user manual that explains that feature. It’s on page 11.
2helpful
2answers
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
2answers
My washing machine is just washing draining but not spinning
IFB is most of the main manufacturers of the washing machine to be had in the market. The brand has brought modern designs and technological improvements for bringing range washer vacations to purchasers. Are you seeking out IFB washing machine service and repair benefits for your area? IFB Washing machine service center in Hyderabad can be outcome cloth washer to end provider measures makeshift. we're managing each description of manufacture.our skilled expert have a power, we additionally accurate other proper brands. The professional preference for all-around handover and affordable perspective. Our education commitment to give the fine reaction for our clients with, especially overall performance rate. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
2helpful
2answers
MHOW UNLOCK THE CHILD LOCK LG WASHING MACHINE MODEL WF-T7516HN
The "CL" code is not an error! This means "Child Lock"!
To unlock the washing machine you will press and holding within 3-5 sec two button, marked "child lock if you have any further questions message me back or this solution does not work message me back the make and model of your machine and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Top IFB Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
