Question about Samsung SCH-u410 Cellular Phone
My Samsung r-410 nam has been switched to nam2 and it restarted its self and now it keeps saying initial programming needed and it keeps asking for a 4 digit lock code and i have entered everything and it is not working. I switched the NAM to NAM2 and now it is lock and won't ulock unless I have a 4 number code.
    Problem Solver:
  • 5 Answers
Switch it back i have the same phone its so easy a baby can do it
Posted on Aug 03, 2009
When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
My lgkeybo says initial programming needed HOW DO U FIX PLZ HELP
on all you need to do is go to settings and look for NAM in the phone setting. once you found that make sure its turned on to NAM1 if it is and you still have that message try NAM2. if none of this works call you service provider.
hope it works
Mar 19, 2009 | LG 10X DVD IDE 452000078
INITIAL PROGRAMMING NEEDED ON JUKE?
you can't fix it you have to get a new one...the same thing happened to me and im getting a new one
Dec 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
My phone keeps on saying initial programing needed.
the solution is that you have deleted all files off your phone. so you have to take it to the verizon place so that they can reset it or if it's bad enough you can go get a new phone!!
Hope i was a help
Dec 24, 2008 | Samsung SCH-U470 Juke Cellular Phone
NAM2 locked.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=22&AT_ID=87077&ARS_ID=9833651
its in the samsung frequently asked questions. All you do is go to windows calculater turn it to HEX enter the hex number under your batery switch the calculator to dec and the last 4 numbers is the NAM2 code
Oct 26, 2008 | Samsung SCH-u740 Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
"initial programming needed" problem
I can not guarantee this Punksk8er but, i did the same thing with my phone by switching the battery with my mother's and I ended up with the initial programming needed sign. This is how i fixed it...
Go to...
>Menu
Select the option...
>Settings
Scroll down to...
>Phone Settings
Then Select the option...
>NAM selections
There you will see the options
>NAM1 &NAM2
Mine was on NAM2 and i switched it to NAM1.
The system restarted and the error "initial Programing needed" went away.
I am no phone expert or anything so I don't really understand how it works but i hope this helps you out dude.
Feb 01, 2008 | LG VX3300 Cellular Phone
Samsung SCH-u410 Cellular Phone Logo
209 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
