Question about Fuji FinePix 1400 Zoom Digital Camera
FinePix 1400 won't turn on, it beeps and shuts off immediatly
My finepix 1400 has fresh new batteries, it has a memory card in place. When I try to turn it on, it beeps and turns itself off. I can't find my usb cable for the camera, I wasn't trying to download pictures so it isn't exactly the same as a previously posted problem. Is it toast?
    Genius:
  • 2,985 Answers
Toast it seems to be but give a look into Fuji tech support team
Posted on Jun 03, 2007
Memory card is full but when try to download to computer says no pictures
Buy a memory card adapter that plugs into the usb port of your cumputer. turn off the camera (important) before removing the memory card. Place the card into the adapter and plug the adapter into the computer's usb port and download the pictures into the computer. You MUST turn off the camera before removing or replacing the card to avoid ruining the card.
Dec 25, 2012 | Fuji FinePix S700 Digital Camera
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
Fuji finepix s800 lens error message
Hello and welcome!
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
if further assistance required, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Apr 08, 2011 | FUJIFILM FinePix S800 Digital Camera
My finepix s9000 will not turn on, it clicks a few times and then there is no power on screens or other features
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
Jul 09, 2010 | Fuji FinePix S9000 Zoom Digital Camera
From where I can buy memory card for finepix E510 camera
The Fuji Finepix E510 takes a memory card type called "xD Picture Card". You can buy it most retail stores, but you'll save a lot of money buying online.
The Upgrade Place has low prices and a Camer Memory Finder Tool. See the capacities available and click to buy xD Picture Cards at discount prices here: FujiFilm FinePix E510 Memory Cards
May 12, 2010 | Fuji FinePix E510 Digital Camera
The camera FujiSD8000 i have won't turn on. Used fresh batteries, has not gotten wet, but i was recently involved in a car accident and the camera was in the car with me when it happend. The camera looks...
Check the memory card or battery door for the tab that activates the cut out switch. It ,or the switch, may have sustained damage. I'm not 100% on this model but if it's like the S5700/ S5800 models then the memory card door has a tab for the cut out switch to prevent card removal whist powered up.
Apr 08, 2010 | Fuji FinePix S8000fd Digital Camera
My fuji finepix s5600 shuts down when i want to take pics,
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Jan 07, 2010 | Cameras
Pictures will not transfer to the computer.......
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 21, 2009 | Kodak EasyShare C613 Digital Camera
Fuji FinePix 1400 Zoom Digital Camera Logo
223 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
