Printer does not print . Just installed it. It printed 6 pages of different documents then when I had found something else I wanted to print, Nothing not even an error message. Its a LEXMARK SERIES 1300 PRINTER .
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Trying to print a 15 page word document but the printer keeps printing only one page repeatedly even though i have clicked print all as well as pages 1-15
I've had similar issues and here's what I found was the quickest and easiest solution. Select, cut and paste the entire document into a new document with a different a name. Sometimes the document format gets corrupted while typing.
Aug 06, 2014 | Canon Pixma MG5220 InkJet Printer
I dont know how to prtint
here are some steps to print document.(just make it sure that your printer is properly installed in your computer.including the printer driver.
1. 1
Open a program that allows you to insert text into a document or get on the internet.
2.
If you were to open a program, you would need to type text into the document. If you were to get on the internet, you could skip to step 7.3.
After you have typed text into the document, you need to locate the menu bar, click on file, then point to print.4.
Click on print.5.
When the print dialog box appears, select the printer you want to use (if it is not already selected) and select the number of copies to print.6.
Click OK.
7.
If you were to print a page or pages from the internet, follow steps 3, 4, 5, and 6, except you don't have to type text into a document to print.
Sep 23, 2011 | Office Equipment & Supplies
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
How to install brother mfc 420cn
In order for your printer to work, you need a Software Installation CD (If you don't have it, you can found it on internet as a "driver" or "software"). For your model, click HERE , download this driver and then install it.
I hope I helped you!
May 15, 2011 | Brother MFC 420CN All-In-One InkJet...
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
Only one half of page prints.
My suggestion would be to totally un-install the printer and erase all traces of the driver(s). Search for them after the un-intall and erase them manually.
Re-install the printer and driver...reboot if nessasary...align the print heads...do a test pattern...then try and print your document. It might just be a corrupted driver...some would suggest just installing over the existing driver...but I've found doing it that way gives you the best chance of it working the first time.
Apr 24, 2009 | Epson Office Equipment & Supplies
Document printing
you will have to change this setting in printing software settings , also make sure when you print something that it says current page only or page numbers selection is set to only print the pages you want
need more help?
Nov 05, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Printer queue is full
This problem seems to be related to USB printers and print queue issues are very common in Mac OS computers and Windows 2000 PCs.
You don't say if you are using a USB connector, but they're pretty common these days. You also don't say if you're using a Mac or PC, but most people use PCs. I did find a solution for this issue that says it's related to Windows 2000 and a USB printer, but may apply to other operating system platforms:
Print Jobs are Stuck in the Print Queue
The first step to this solution is to download and install an HP diagnostic software utility. There's a separate page at HP that describes the utility and lets you download it:
HP Printing and Diagnostic Utility
I didn't find any information that specifically said that you "can" print a test page but "can't" print a document.
Another reason why you might be able to print a test page but not a document isn't related to the printer but the application that created the document. If you are having trouble with Word or Excel or whatever office application you used to create the doc, it might not print. That's why it is helpful to try to print a variety of different docs, created with different apps.
It could also be the individual document. Occasionally, a document becomes corrupted and while you may be able to open it (and sometimes you can't do even that), it doesn't print. If you haven't tried printing more than one document, you can test this by creating another doc in the same app and seeing if it'll print.
Try doing test prints with different docs and then with docs created in different apps. If those work, it's doc/app related. If they don't, try the links I suggested above.
Good luck.
Sep 21, 2008 | HP Officejet 5610 All-In-One InkJet...
41 people viewed this question
jasbo
jasbo
