Question about Kenmore Refrigerators
Vegetable & Meat Tray Freezing on refrigerator
I have a Kenmore #106-57022601, Serial # ST 2357042 side by side refrigerator that I purchased around 8 months ago. The vegetable & meat tray are freezing the contents. I have tried adjusting the lever both ways and when placing a small glass of water in the meat tray it continues to freeze. I have the freezer sat on the lowest setting.
Do these freeze up in the winter months?
How can I stop this from happening?
Would this be covered under warrantee?
I appreciate any feedback and help.
  • 700 Answers
You have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Posted on Jan 08, 2009
My Kenmore side by side fridge isn't cooling hardly. Feeling the suction and discharge lines I think it's low on freon. How do I charge it?
Well I have to go, so I can't wait for your reply for more info. Basicallty what happened to me was the freezer became very good at freezing. The problem with modern freezer/fridges is that there is only one cooling system, the freezer. The freezer chills the other side to chill the refrigerator. Something was blocking that vent into the fridge side. Turns out it was ice blocking the vent into the refer side. It happens when it is humid and the kids to "shopping" in the fridge and leave the door opened for extended periods of time.
If you are blocked by stuff in your fridge, move it away from the vent. If nothing there, you'll need to get ready for a bit of time. Side-by-side freezer/fridges, typically the freezer is on the left. So, open the fridge, somewhere near the back about 2/3s of the way down, just above the vegetable bin, on the left side. Remove the cover, if something is stuck in there, gently try to remove it. If it is ice, like I had, you should remove your vegetable bin and meat bin and unplug the unit (to prevent shock as water will be everywhere. Be sure that your overflow tray (under the unit) is empty. Next is to make quite a bit of boiling water (I ended up using just over a gallon). If you are at the point where you can't get the cover off, you'll have to use a baster to melt the ice that is holding your vent cover on (that is where I started). Then you can start working on the ice. You need to keep putting water in until you get hot water in the overflow tray. Replace your food and don't slam the fridge control all the way to the coldest setting, you could end up freezing your meat and vegetables.
The repairman came and told us, he could do this for us for $200 or we could do it ourselves. He would have done the exact same thing.
Feb 05, 2014 | Kenmore Refrigerators
Vegetable compart freezes the vegetables
You probably have your compartment set to meat and not produce. Adjust the setting on the tray, or get the food further away from the air return ducts.
Jan 23, 2012 | Kenmore Side by Side Refrigerator
My vegetables are freezing in the vegetable/meat bin. How can I keep them from freezing?
Check your settings for your thermostat. Turn it down in increment's one letter or one number at a time. Higher letters and numbers normally mean lower temperature. Also, the veg bins have settings also.
Feb 13, 2011 | Kenmore 57029 Side by Side Refrigerator
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Your Feedback
the settings that you said sound correct, you do not want your vegetables to dry out and shriviel up. The meat compartment should be running around 31-33 degress to keep the meat fresh, basically that is the ideal situition for you. Do you store allot of ice cream ? thats the only thing that needs to be extremely cold (-10) degrees. Best to keep in a deep freezer not the one inside.the only thing that I use mine for inside is ice and food that is going to be ae real quickly. long term storage is best in a deep freezer that you have to manually defrost. That way it neveer freezer burns the food. Hope this helps out.
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
547 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
