Question about HP iPAQ rw6828 Smartphone
Can't open casing for ipaq rw6828
I have a problem with my IpaQ rw 6828, panel for bluetooth/infrared was stuck on the stylus hole. Could you help me how to open the ipaq casing ?
  • Anonymous Jan 15, 2009
    Bro, I had the same problem. It's not that easy to open unless ur familiar with opening hp or pda casings. After u open the battery cover, you will see 2 screws at the bottom. You have to pop open the top cover using a small flat screw driver, and u will see 2 additional screws at the top. I did not do it myself, I had mine opened by a technician at the IOI mall in Puchong at the 3rd floor. And the guy was so nice, he did it for FREE!!!
I've managed to open mine when the infrared screen pushed in. See the guide from the link below. Well, sorry for my bad English in the guide... :D
http://adhi.widjajanto.net/blog/archives/2009/01/how_to_open_hp.html
Posted on Jan 17, 2009
Reset
hp ipaq rw6828 forgot the password
Jun 04, 2013 | HP iPAQ rw6828 Smartphone
Hp ipaq rw 6828 modem driver not installed looking for free download driver
Here lol:
http://personalcomputerdeni.blogspot.com/2013/03/hp-ipaq-rw6828-multimedia-messenger.html
Dec 18, 2012 | HP iPAQ rw6828 Smartphone
Hp iPAQ rw6828 forget password for unlockcord
My phone imei no 358065000692054 please my passwod code
Oct 05, 2010 | HP iPAQ rw6828 Smartphone
How do i put the unlock code in a ipaq rw6828
On the start up screen when the phone say's 'wrong sim' or some such. type in the unlock code. Usually it begins with a pw the can be attained be repeatedly pressing the * or the # button's.
Jun 30, 2009 | HP iPAQ rw6828 Smartphone
Ipaq H3630 how to do a hard reset
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Aug 29, 2008 | Compaq iPAQ H3630 Pocket PC
HP IPAQ RW6828 Audio Loop problem
HI,
THIS IS VISHU HERE, IT SEEMS THAT THERE IS SOME PROBLEM IN YOUR AUDIO SOCKET.THE SOCKET WHERE WE CONNECT THE EAR PHONE , BCOZ NORMALLY WHEN WE CONNECT THE EAR PHONE ON A GOOD WORKING DEVICE IT CUTS THE AUDIO FROM MAIN SPEAKERS/MIC AND ROUTE IT TO EARPHONES , THIS FUNCTION IS PERFORMED BY METALIC CONTACTS PRESENT WITHIN THE SOCKET THE PROBLEM IS WITH THESE CONTACTS MEANS THESE CONTACTS ARE REMAINING IN CUT OFF POSITION EVEN AFTER REMOVING THE EARPHONE .
TRY TO GET UR SOCKET REPLACED , HOPE IT WILL SOLVE UR PROBLEM.
MAIL ME UR REPLY @ vishwas_4urediffmail.com
Jan 08, 2008 | BoxWave Corporation HP iPAQ rw6800...
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
Can't open my home page
Try to soft-reset your iPAQ; depending on the model of iPAQ you have the soft-reset hole is located on the left hand side or bottom of your iPAQ; press the tip of the stylus into this hole to reboot your iPAQ.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rw6828 Smartphone Logo
442 people viewed this question
Top HP Cell Phones Experts
Bill Boyd
D. E. Hev
Andrew Taylor
Andrew Taylor
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
