Question about Samsung Cell Phones
Need to undo LCD on Samsung A701
My LCD on my Samsung A701 phone is not working and I need to swop it with another. I have undone the two small screws at the bottom of the flip up but can't seem to pry the cover off. I am afraid of damaging the little camera as well. Whats the next step? Are there certain points I need to press..... or ? All help much appreciated Keith in Adelaide
SOURCE: KYOCERA SLIDER REMIX FACEPLATE INSTALLATION
I had the same problem and I was lookin on a forum/blog on how to do this,but not many helped.I'm about to attempt to change my faceplate and I noticed when you take the battery cover off,there are 4 screws under the cover,and one near the antenna.You probably have to take apart the back part of the phone to get to the screws that are attatched to the sliding part of the phone.Its probably a little risky and tricky,but Im guessing thats how you get to the 2 hidden screws.
Posted on Dec 20, 2007
Adolph
  • 137 Answers
SOURCE: Samsung DH500 cell phone
Take somebody else phone, Hold them togeather and go step by stem throug the menus until you get what you want. Its only a way of nowing what must be on the screen when you press the buttons. Connect and download.
Posted on Dec 25, 2007
Bajanguru
  • 7752 Answers
SOURCE: top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Posted on Sep 20, 2008
SOURCE: samasung shg-l810v
http://youtube.com/watch?v=_owancND8R8
Posted on Oct 26, 2008
  • 19 Answers
SOURCE: Chevy S10 extended cab third
This is a very easy fix, I ordered a new metal one off of ebay came with instructions and was very easy to do.
Search CHEVY S-10 THIRD 3RD DOOR HANDLE 1996-2005 GMC SONOMA
on ebay, the sellers name is s.gifenigma326 very easy to work with cost 15 bucks, shipped on time.
Posted on Jan 09, 2009
I'm trying to replace the fan in my NEFF oven. I've removed the nut and the locating washer but am left with a fan blade that is flatly refusing to come off the spindle.
the fan normally has a small set screw buried in the boss of the fan. You need a small Allen key to undo it.
Mar 13, 2018 | Ovens
Battery replacement procedure for Casio 901 DW-5600?
hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
Lost SGH-A701 charger
If you cant find a new charger from stores, you can always hunt for it on ebay or you can use the following Desktop charger which can be used for all mobile phone batteries. it is called a Generic battery charger.
Jan 30, 2010 | Samsung Cell Phones
Can't access samsung sgh-a701 user manual on your
Thank you for visiting FixYa!
You can view your owners manual at the following website. It's in PDF format. If you need a PDF Reader you can download Adobe Reader for free.
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
http://tiny.cc/FixYa323
Jan 29, 2010 | Samsung SGH-J600 Cellular Phone
How do you replace an LCD screen on Nokia E66
Undo 6 screws on back of rear housing, [2 near sim reader, rest on body .] When back pops off , be careful to release Sim flex , as it will tear easily. Disconnect main flex between 2 halves of phone.Remove main board , then undo 2 small screws at the top of phone .This will release the front housing. The LCD JUST FLIPS OFF THE CONNECTOR ON THE FRONT FLEX, be gentle with the handset and removal! . To rebuild , just repeat in reverse, as is quite simple, but BE GENTLE!!
Sep 15, 2009 | Nokia E66 Smartphone
How do you replace the lcd screen on A LG shine KE970
Take off the back plate that houses the battery, undo the four screws, then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a futher six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like moulding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD. All you have to do now is remember which screw goes where and reverse the whole process. Good luck.
Feb 08, 2009 | Cell Phones
Password
you could try *2767*637# if no luck try 00000000 8x0
If that fails go to mobile2mobile, you will need the data cable for the unlocking software I found this with a google search http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm
Just posted unlocking software for samsung A701
Nov 08, 2008 | Samsung SGH-e315
SGH-A701 Mobile USB Cable
G'day,Mate !!...My own personal experience with 'Samsung PC Studio' is...it is ,to put it mildly,obsolete,unless they have updated it.Also,I believe you are referring to a phone that was brand new in 2006.You could TRY using Samsung Kies,but,again,in my experience,that is a colossal waste of time ,also.Have you tried plugging phone in while computer is shut down,then powering computer back up ??
May 09, 2017 | Cell Phones
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
