Question about Dell (310-1925) (2R905) KVM Switch
I have a HP eo1010 kvm switch, how do I go about switching from server to server on it?
By default to bring up the On Screen Display press:
CTRL + CTRL
If you flash the firmware to the latest, you can change that key sequence for the OSD to either PrintScrn, CTRL+CTRL or SHIFT + SHIFT.
Posted on Apr 02, 2011
If you have all the cables, and servers hooked up to it that you want, try using the "Print Screen" key to toggle between the different servers.
A.
Posted on Mar 03, 2009
    Scholar:
  • 143 Answers
U need to connect both server kb/mouse/monitor and just connect yr.cable lanth is about mex. 4 to 5 mt. otherwise it's lost
Posted on Jan 08, 2009
Connecting hp 513735 kvm to a datacentre. Monitor to vga on kvm. Vga on cable to srvers and rj45 to kvm 8 x rj45. cannt see any servers. Menu dont display any server after pressing prntscrn. What i'm doing...
this user manual may help you have to configure the switch first with a IP address and subnet mask that will let the switch see the server.
I am not totally up with hp but it looks similar to Cisco switches in that you have to configure the switch. I am studying Cisco at the moment and this seems similar.
http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01931438
Feb 16, 2015 | HP Computers & Internet
How to connect my lcd kvm and make it display on sreen
You question is unclear. Please specify the makes and model of all devices. I typically use Rackmount Monitor Keyboard combos with integrated KVM Switches for larger server applications. I have used quiet a few units from KVMSwitchTech and they work pretty well.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
Problem:HP 336044-B21 8-Port KVM Switch do not seems to function properly, green light is not coming, sometime blinking, rack monitor do not show any signal coming from server, although the cable from...
You may have a bad ethernet cable. I would try the easy thing first and just go to Best Buy, Amazon etc... and purchase a new RJ45 CAT5 or CAT6 ethernet cable. Since you are receiving an orange light it is indicating that the port is not active. Also check the cable make sure its seated properly at both ends even with a new cable. Cheers! Hope it helps! J the Guru.
Oct 16, 2017 | HP (336044-B21) 8-port KVM Switch
Reboot of linux server hangs
It should not be the cause of problem, kvm switch is an intelligent device. Turn off the device, unplug the wires do not unplug them for a minute or so, plug them in and turn it on. It should work if not call the customer support.
Nov 19, 2010 | Altusen ATEN CS1804--4 Port Sun KVM Switch...
The KVM is unresponsive, meaning the buttons are no longer operating the way they should to go from one server to the otehr no reaction.
try tapping scroll lock twice then arrow keys. sometimes you need to start the server/computer with the kvm plugged in to get the computer to "recogize" the KVM is there. otherwise it looks for other devices Always start the computer with KVM on the respective channel. Then use it to switch. Cheers.
Aug 24, 2010 | HP (336045-B21) (336045B21) 16-port KVM...
We have just installed 2 x new HP KVM switches (main port 16 connects to A port on secondary switch) with HP TFT7600 rack mount monitor and keyboard. Issue is we cannot connect to Servers on secondary...
Try swapping the switches over, your second switch box may be faulty.
You could also check the ips to make sure u have no conflicts.
post back what you find. thanks
Jan 19, 2010 | HP (AF600A) KVM Switch
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
8 port kvm console switch
KVM switches are hardware based and there is no use software.
Aug 22, 2006 | HP Console Switch (J1474A) 8-port KVM...
Dell (310-1925) (2R905) KVM Switch Logo
1,401 people viewed this question
Alun Cox
