Question about Cell Phones
Ring tone problem
My ring tones on my nokia mobile phone does not ring even no vibration when one calls.
    Sergeant:
  • 221 Answers
There r three modes. 1)ring mode. 2)vibration mode. 3)silence mode. so it would be on silence mode.just make it ring mode from silence mode. which can be done by going into settings then in to ringer and volume option.in that you can select. thanks.
Posted on Jan 08, 2009
Hai my sony j108 low sound on ringar how to cler
Posted on Jun 25, 2013
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
My mobile in not displying anything in the screen
If your phone notify the incoming calls by vibration or ring tone then you just have to change the LCD of your phone.But if it is not ringing the ring tone for incoming calls then your phone may have big problem like dead.So in this case you should go to any service center to save your phone.
Dec 20, 2009 | Nokia N95 Cellular Phone
When someone calls me, the phone vibrates but no ring tone. what can i do the get a ring tone my phone is nokia 2630
well first reset ur phone then try if still no ring........then there is a hardware problem in ur phone replace ur speckers
Nov 18, 2009 | Nokia N73 Cellular Phone
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Ring and vibration does not work simutaneously
ya it is possible you should re configure the setting of your mobile.check the tone or melody setting of your mobile care fully.if problem not solve then tell me again.
Mar 08, 2009 | Samsung SGH-D500 Cellular Phone
My phone has no song at all
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Nov 19, 2008 | Nokia 1100
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
365 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
