Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony 53" HDTV "high Voltage" reading.
What does it cost to replace the "D board" ? and is this usually the only problem with the High Voltage reading?
Thank You
  • ddy410 Jan 12, 2009
    Thank you.
  • Sony Master
  • 8,617 Answers
The D board for your model cost about 300.00 you can get one at the following link.
http://servicemanuals.vstore.ca/
Posted on Jan 08, 2009
I am getting 5 blinking red lights before going solid red; already replaced the projection lamp approx. 1yr. ago My Sony 50" KF 50WE610 model is about 7 yrs. old. Please give me some guidance
Hi dalposadas,
5 blinks of the standby led lights is an error code for no high voltage coming from the ballast board.
You have to check first if the supply voltage from the power supply is present feeding the ballast board. If yes, you have to replaced the ballast board. High chance that the fault came from it but you need to confirm it by the presence of the voltage from the power supply.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony KP 51W520 won't come on. The standby light flashes 10 times. I read through the other people's problems listed here and everyone else has had either 3 blinks or 9. Any thoughts?
Hi.
it seems that your power supply or high voltage section is failing. Look for PWM IC genarator. MCZ 3001D on Power supply and near high voltage section. Try to replace these IC's.
Jan 05, 2011 | Sony KP-51WS520 51" Rear Projection...
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Blurry picture. Red & green ghost. I am currently removing the circut board to replace the amplifiers. How do I remove the high voltage wire from y=the transformer
Not any amplifiers problems.The problem u having it known as covergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D look like pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board to solved the picture convergence problems.The Shop,will cost u $300-350 for parts and labors.
Oct 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Our TV has sound but no picture. Is there a reset button? Could this be a problem with the lamp?
suzy arata,
This unit has CRTs and does not have a lamp. Most likely you have a problem in the high voltage section. This can be checked with my tip at http://www.fixya.com/support/r4916941-diagnose_repair_projection_tv_high which explains the problem although it was written with a dead set in mind. It also tells you where to get the best price on parts. There is an outside chance that you could have a video drive issue. This problem would be on the other board (not the board with the high voltage). There really isn't a way for you to troubleshoot this board. If you do not find any problems in the high voltage circuit I would replace the small signal board. Available from http://www.encompass.com.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 20, 2010 | Sony KP-53S25 53" Rear Projection...
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
Removing D board
You can get the entire service manual emailed to you at the following link. It cost 10.99 and comes with unlimited free support to help you with your diagnosis your problem.
Feb 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
No picture
This looks like a problem with the Hv Voltage section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, or have this done by a qualified TV technician.
Or check the voltage test points on the HV / Horizontal board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I would suggest that if you do not have a background in electronics that you have a qualified electronics technician who knows TV take a look at your set and perform these test.
I hope this helps,
Thank you,
Shuttle83
Sep 17, 2007 | Sony KP-46WT500 46" Rear Projection...
Getting my tv crisp and fixing hdtv
check to see if set appears to have a slight high voltage arc or corona discharge that is causing interference to other televisions. This arc is also causing problems in the video circuit which is why the tech and the customer are seeing it on the screen of this television. Tech needs to isolate the High voltage block, and CRT from possible suspect by one by one disconnecting them from the high voltage source. The only indicator the tech can use is another television and look for the interference to disappear, since the Sony will not allow the raster to appear if any one of the tubes is disconnected. After the test the it was determined the flyback was causing the problem. The radiated noise reduced but was did not disappear. It was recommended to replace the "G" board since the unit was covered under the SAYS program.. The G board corrected the symptom.
Nov 28, 2006 | Sony KP-53V85 53" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
