Question about i-mate K-jam Smartphone
I-mate K-Jam synchronisation problem with my new PC
My i-mate will not synchronise with my new PC, but it was fine with my old PC. IT at work cannot help and can only suggest returning to default and start again (which will mean I lose all contacts and items in calendar). Can someone help please?
Thanks Shebadog1
  • Jo Dumergue Jan 09, 2009
    Hi there, I am using the software that came with my i-mate. Maybe
    there are updates for it, as I purchased i-mate about 4 years ago.
    shebadog1
  • 42 Answers
What s/ware are you using for synching and does the PC see the device at all? The s/ware needs to be asked to look for new device. Have you still got old PC...then connect to it so you have a backup.
Posted on Jan 08, 2009
Free Software to Download
go here
http://gallery.mobile9.com/c/imate-jam-java-software_159/1/
Sep 20, 2009 | i-mate JAM Pocket PC
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
LG Viewty pc connection problems
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Dec 30, 2008 | LG KU990 Viewty
How to restore i-mate to the factory settings
how to synchronise imat jam with computer?
Nov 27, 2008 | i-mate JAM Pocket PC
Problem with i-mate
Try ( wm5storage) software
Oct 10, 2008 | i-mate PDAL Pocket PC
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
Drivers for imate jam
http://www.ziddu.com/download/3568715/Imatepcsuitactivesync4.zip.html
here is the software for your imate pocket pc.
if you want more softwares or any other things please send me your e-mail. I'll send you More Links.
my e-mail : dhanushka_priyankara@yahoo.com
May 25, 2008 | i-mate JAM Pocket PC
I-mate K-jam synchronises great on my Vista PC but my XP laptop found new hardware wizard can't install USB drivers. Phoned handed down from my son who no longer has the disk so where can I download the...
I discovered that the drivers should be provided with MS ActiveSync. I upgraded to the latest version ov ActiveSync (4.5) and everything works fine.
Mar 05, 2008 | Lands Phones
Synchronising to ipod
I'm glad you solved it yourself. It would be helpful to post the solution to help anyone else with the problem.
Jan 01, 2008 | Samsung YP-K3 MP3 Player
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
i-mate K-jam Smartphone Logo
64 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
