Question about Husqvarna Chain Saw 20" Bar
350 HUSQVARNA HAS SPARK WON'T START
I TRIED GAS IN SPARK PLUG CHAMBER NO LUCK. JUST ACTS LIKE IT WON'T AT ALL WHAT ELSE CAN I TRY.
ALSO HAVE A RANCHER MODEL THAT DOESN'T WANT TO STAY STARTED,I TRIED ADJUSTING THE LOW AND HIGH MADE IT BETTER AS LONG AS I STAYED ON THE THROTTLE,WHEN I GO TO MAKE A CUT IT BOGS OUT
  • 181 Answers
Never,never put starting fluid in a two cycle motor,it drys the cylinder and rings out,rancher 350 has had a problem with burning the piston and cylinders up.pull the muffler off and see if there are score marks in the piston.if so you need piston and cylinder,call husqvarna and check for warranty.......depending on age of machine they will either cover it all or you may have to pay some for repair
Posted on Jan 09, 2009
    Scholar:
  • 98 Answers
Clean air filter and try starting fluid through air intake if you have spark this will definetely start it......On the rancher , is the air cleaner clean??? Remember that all you need to make an engine run is fuel , air , and an ignition source .. When you attempted to start the Husqavrna by adding fuel to spark plug chamber this actually causes a no start or very hard start condition it will act like if flooded....What does help if you remove the spark plug pull the pullstart and ensure that no liquid (gas is coming out of chamber) if it is keep pulling until it does not.... then take your spark plug ,after you have cleaned and gapped it, and with a butane lighter heat the tip for approximately 30 seconds and then reinstall plug and give it a yank after you spray starting fluid in the air intake....Good Luck
Posted on Jan 08, 2009
Wont start, spews fuel out of combustion chamber, spark plug wet
sounds like the diaphram in the carb ..you will have to take carb apart clean and rebuild or just purchase new carb, I believe there are not to expensive, about 60 bucks..hope this helps..good luck
Sep 06, 2015 | Husqvarna 460 Rancher 24" 60cc Gas Powered...
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
3 month old Husqvarna 235. Refuled. Won't start. Plug is firing. Primer bulb gets full. Still won't start.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Jun 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 55 rancher - I rebuilt this saw but now it won't start. Seems like not getting enough gas. What should I check for?
Check for plugged fuel filter and muffler. Check the fuel lines for decay or damage. Did you service the carburetor? Make sure the lower chamber diaphragm is not hard or cracked. Did you change the two jet settings? Put some fuel mix into the plug hole and pull it through--you should get a pop or two. If ok, then concentrate on the fuel problem. If no spark at the plug, check the ignition module gap to the flywheel magnets using a thin business card for a gauge. Hope this helps!
Jun 06, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Chain Saw 20" Bar Logo
540 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
