Question about Sony PlayStation 2 (PS2) Console
Ps2 cd tray does not open and the eject button light flashes
When you switch the playstation on the eject button light continuously flashes green and the disk tray does not open
  • Anonymous Jan 08, 2009
    Mine just started this today too...
    same thing, green light flashes, no response from the open tray. cannot reset.Tried to pry open the tray to get the game out, that didn't work.
  • 21 Answers
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Posted on Jan 10, 2009
  • SBL Games Jan 11, 2009
    It may also be that your eject motor is going out. You should probably have someone inspect your PS2 and provide a diagnosis for this issue.
How to on ps2
  • Find a clear space, preferably out of direct sunlight, to set up your PlayStation 2.
  • Plug the AC adapter into the designated area on the back of the PlayStation 2 and then plug it into the wall socket.
  • Plug the RFU adapter or audio/video cords (depending on the model of your television) into the back of your PlayStation 2 and then into your television.
  • Plug your controller into the controller slot adjacent to the disc tray.
  • Plug your memory card into the memory card slot above the controller slot (see "How to Managage a PlayStation 2 Memory Card").
  • Turn your PlayStation 2 on using the on/off switch on the back of the PlayStation 2.
  • Press the eject button to open the disc tray. Insert a game disc and press the eject button again to close the tray and begin play.
  • Turn the PlayStation 2 off when done playing by either flipping the on/off switch or pressing the sleep button.
  • Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
    Green light turns on but blue light dosent turn on. Also the ejection tray dosent come out.
    ahh my friend had the same problem
    if you had opened your ps2 the cord connecting to your motherboard for the tray the cord probably came off its a gray cord you take your ps2 apart and it connects the top part to the bottom part just reconnect it to the insertion point it connected to and you should be back in businesas
    Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
    Disc tray wont open when eject button pressed on ps2
    The disc tray motor needs to be replaced. You can find one on ebay. A relatively easy fix. Good luck!
    Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
    Getting ps2 micro switches realigned
    micro switches is wat turns on and off the PlayStation2 and they make the Cd tray come out and resets the ps2 the buttons are the green button on the front of the ps2 to restart and turn on the ps2
    and the blue button is at the bottom of the green one the blue button makes the Cd tray come out and the last micro button it at back of the ps2 its a black button that turns off and on the ps2
    your rating is highly appreciated
    Jun 23, 2008 | Sony PlayStation 2 Slimline Console
    Playstation..2
    Hi Sammy,
    You have a connection problem in the Reset Eject circuit.
    I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
    1. Disconnect power and turn the case upside down.
    2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
    3. Remove all the screws.
    4. Remove the Warranty sticker to the right edge of the power socket.
    5. Turn the PS2 over to set it right side up.
    6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
    7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
    If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
    Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
    Playstation 2 power button
    Try pushing the eject button to see if the power button is faulty. If the PS2 is off and you press the eject button, it automatically turns the PS2 on and ejects the DVD tray.
    Sep 08, 2007 | Sony PlayStation 2 (PS2) Console
    Ps2
    hi check if the button is stuck you might need to open it becareful not to disconect anything and if you do first see were it goes ho it helps.
    Jun 22, 2007 | Sony PlayStation 2 (PS2) Console
    Won't boot up, can't eject disk tray
    buy an xbox i mod them and have absolutely no problems
    Jun 01, 2007 | Sony PlayStation 2 (PS2) Console
    PlayStation wont power on
    The jumper between the buttons and motherboard may be disconected. Open up your ps2, see if there is a blue /white ribbon cable that is unpluged. If you have already opened your ps2 rrior to this, thr case map be jamming the button.
    May 06, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    620 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
