Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Does the Motorola Talkabout T5720 communicate with a other Two-way Radio that is not Motorola or is a different model? And does this Two-way Radio have the scan option? Thanks
    Problem Solver:
  • 13 Answers
Yes, it does scan. but motorola 2 ways may have a different freq. than the other 2 way radio you have. search through both radios and find the channels that match.
Posted on Jul 08, 2007
  • 123 Answers
All Motorola Talkabout can communicate with other FRS radio, Scan, this model does not have this feature.
Posted on Jun 01, 2007
Why is not possible to communicate from T5720 talkabout to T5422 talkabout?
The two radios share no frequencies in common. The T5720 has the US frequencies classified as FRS and GMRS, between 462-467 MHz. The T5422 has the UK frequencies classified as PMR and dPMR which are in the 446 MHz range.
A list of UK frequencies can be found in this forum: http://www.transmission1.co.uk/forum/viewtopic.php?f=4&t=23400
Best regards.
Oct 01, 2012 | Motorola Talkabout T5720 (7 Channels)...
BAGAIMANA CARA MENGUNAKAN MOTOROLA TALKABOUT T5720
Here is a link to the user guide for the Motorola TalkAbout T5720. I only could find it available in English. You will need to translate into Indonesian.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 17, 2012 | Motorola Talkabout T5720 (7 Channels)...
Where can I buy repair parts for my Motorola T5720 Talkabout radio?
So sorry, parts have never been available for the TalkAbout line of radios (other than TalkAbout Distance & DPS). If you are looking to repair an existing T5720 unit, your best option would be to locate a like-model for parts. eBay can be a good source.
As for replacement batteries and accessories you can use the Motorola TalkAbout Accessory Store.
Best regards.
Mar 20, 2010 | Motorola Talkabout T5720 (7 Channels)...
I had a pair of t5720's but lost one of them on a trail somewhere in Arkansas. Where can I order a replacement?
You could try eBay, or Motorola's online store http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601700
or you should be able to get a similar unit at your local Walmart. The T5720 has not been produced for a while, but other TalkAbout radios will communicate with your existing radio.
Best regards.
Feb 18, 2010 | Motorola Talkabout T5720 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
I want to communicate from t5720 talkabout to midland lxt303. When I set them to the same channel the talkabot gets out but will not receive unless I press the MON button on the face of the radio
Set your interference eliminator code on the T5720 and the Qt filter both to zero. You have one or both turned on. By setting them to zero you will turn them off. Then your radios should work together.
Mar 14, 2009 | Motorola Talkabout T5720 (7 Channels)...
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Aug 21, 2008 | Motorola Talkabout T5720 (7 Channels)...
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
348 people viewed this question
Top Motorola Radio Communications Experts
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
