My USB hard disk is not working - Computers & Internet
Cefg mic d33193
Posted on Jan 08, 2009
120G hard disk doesn't work on p4m266a mother board
The hard disk maybe faulty especially if the BIOS cannot detect the hard disk.
Try connecting the hard disk into an USB hard drive adapter and then plug it into the USB port of a working computer. If this computer cannot detect the USB hard drive adapter as an external storage device then this hard drive is faulty.
Oct 29, 2012 | Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? 2.is there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
When i turn it on it has a disk read error occurred message
The Toshiba cannot find a boot disk, this problem could be caused by the BIOS could not detect the hard drive because has lost the configuration or the hard drive is faulty or the disk controller is faulty.
Check the BIOS configuration to see if it has detected the hard disk and some BIOS have a utility to test the hard disk, if this is available then run the hard disk test.
Another way to test the hard disk, remove the hard disk from the laptop and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see it as and external hard drive and you can open the folders and files the the hard drive is OK and the fault is most likely the laptop's motherboard.
If the computer cannot detect or open the files on the external USB adapter then the hard drive is faulty. The hard drive needs to be replaced in the Toshiba and Windows installed to get the laptop working again.
Aug 02, 2009 | Toshiba Computers & Internet
CANNOT GET EXTERNAL HARD DRIVE TO WORK ON LABTOP IT WANT EVEN REGISTER ON MY COMPUTER THE NAME OF THE HARDDRIVE IS IOMEGA 320GB
Is this a USB hard drive?
If so do any USB devices work?
Check Disk Manager (STart Menu - My Computer - right-click - Manage - DIsk Manager) - Can you see hard disk?
If so right cick on hard disk and set a drive letter for it in Disk Manager.
Aug 10, 2008 | Computers & Internet
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
