Question about HP Pavilion A6010N (882780985575) PC Desktop
Installed new video card but the signal remains black
The on board card developed a problem and could not detect the monitor settings, installed nvidia gforce 7300 but there is no signal to the monitor, i have tried flashing the bios but it didn't work
    Sergeant:
  • 284 Answers
REMOVE THE CARD AND UNINSTALL THE VIDEO CARD IN ADD REMOVE PROGRAMS. THEN REMOVE VIDEO CARD AND INSTALL DRIVERS THEN INSTALL YOUR VIDEO CARD. I HAVE THIS SAME VIDEO CARD AND HAD THE SAME PROBLEM.THIS WAS THE ONLY WAY I COULD GET IT TO WORK. ALSO YOU NEED TO DISABLE THE VIDEO CARD THAT IS ON YOUR MOTHERBOARD. YOU CAN DO THIS IN CONTROL PANEL. ADMINASTRATIVE TOOLS THEN CLICK COMPUTER MANAGEMENT THEN CLICK DEVICE MANAGER GO TO YOUR DISPLAY DRIVERS AND DISABLE YOUR GRAPHICS CONTROLER. THAT SHOULD DO IT. HAPPY NEW YEAR.
Posted on Jan 08, 2009
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
Www.hp.com/go/techcenter/startup
My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
System temperature (90D)
Apr 08, 2012 | Computers & Internet
How do I hide my toshiba bar on the left of my screen. it contains photo/video, settings, effect, face recognition
Point your mouse cursor on it, drag ( hold left click) move it to the top of the screen.
or you can try click setting >> auto hide checkbox
akee.4shared.com
Aug 15, 2011 | Toshiba Computers & Internet
HP Pavilion A6010N (882780985575) PC Desktop Logo
341 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
