Question about Whirlpool GGW9200L Gas Dryer
Automatic cycles are not working properly
When ever i set it to "normal" it could run and run, it gets so hot that you could almost burn your hand and the timer still says 32 min. it will still show by the status " wet"
  • 679 Answers
There are some problem in thermostate; so check them first.
Thanks for using FixYa.
Posted on Jan 08, 2009
  • rockfixya
    rockfixya Jan 08, 2009
    try the link>>
    http://www.repairclinic.com/0088_8_1.asp...
DG 50000. Why is there a hot burning smell when it is running?
The motor, the pump, or the heating element could be getting ready to fail.
Oct 03, 2015 | Indesit Dishwashers
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 14, 2011 | Maytag MDE6000 Dryer
My dryer gets hot but the clothes stay moist and there is dampness on the door when you open it.
Clogged Vent
Heating Element
Cycling thermostat
Apr 13, 2011 | Dryers
Dryer takes a long time to dry. How long should an average cycle take?
The normal drying cycle for a normal load of clothes should be around a hour if you dryer is 220 Volts.
Chances are you have a Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Maytag SDE4606A Electric Dryer
@runs hot motor feels slow doesnt hit hard
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered and properly lubed. If not powered correctly, motor will not turn at full rpm, get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. If you are sure that it is getting proper voltage /amps then may need lubrication or bearing work. Remove bearing cover and turn armature by hand. It should be easy to turn. If stiff, suspect bearing/grease. With amp meter connected, check amp draw and compare to rated amps.
Mar 26, 2011 | Bosch Brute Breaker Hammer 11304
The stainlessvent inside the dryer tumbler side gets red hot after running for half a minute causing clothes to burn
Generic solution offered.
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat.
Proper air flow is required for the dryer to operate normally. Airflow is interrupted when the door or front panel is open and the heat will gain rapidly. Operate the dryer without the vent connected and if it works normally, then inspect/clean/replace your venting. Make sure you clean the lint filter after every load.
Aug 24, 2009 | Dryers
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Older whirlpool dryer gets too hot when using automatic setting
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Nov 26, 2008 | Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Whirlpool GGW9200L Gas Dryer Logo
16 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
