Question about Asrock P4I45GV R5 Motherboard
Cpu running but no beep and display
When I start my computer CPU gets star. But there is no beep and no display
    President:
  • 2,110 Answers
Try to change the RAM...
Posted on Jan 08, 2009
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
No signal to monitor , checked with another source to monitor it is working fine , not sure what to do next
Have you checked if the cable is well connected to the CPU and Monitor?
Also loose the CPU case and check the VGA card if it well fixed to the board.
If a CPU ram is not well fixed to the mother board, there would never be a display on the monitor.
Lastly, check if electric current is interring the CPU. You can know through the power pack fan at the back of the CPU. And check power cables and socket.
Best wishes.
Dec 28, 2009 | E-Machines T6414 (RBT6414) PC Desktop
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Asrock P4I45GV R5 Motherboard Logo
102 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
