Question about Dacor Epicure ESG366 Gas Cooktop
Disassembly to replace LED burner indicator
I've got a ESG366 and one of the purple LED burner indicators is completely missing. It must have fallen out (or into) the appliance. I can order the replacement LED, but I have no idea how to disassemble the cooktop. Either removing the porcelin top, or from underneath the cooktop. I'm quite handy with appliance repair. I was just looking for input from gurus on where to start before I jump in. Thanks much!
I'm not an expert, but I just had mine apart. You should take the panel off from beneath the control panel. This is a matter of removing about 6-8 screws and slipping the small piece of sheet metal out. You may then be able to find your "missing" LED, which is probably dangling inside the control panel assembly area. I believe there is simply a tab or other simply fastening clip that you slip the LED back onto; this holds the LED against the control panel. Assuming the LED is still working and still wired to the knob, it should work fine.
Posted on Nov 26, 2007
SOURCE:
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
Have whirlpool glass cooktop,, the heat indicator light is staying on even though the burner has cooled off completely
This is usually one of the switches has failed. You will need to uninstall and disassemble to acess the switches. They are easy to check and replace. Here is a link that should help http://appliancehelponline.com/infiniteswitchvideo.html You can also enter your model # for diagrams and illustrations of your specific model.
Sep 03, 2010 | Whirlpool Cooktops
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
Jun 12, 2009 | Maytag MEC5430 Electric Cooktop
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Dacor Epicure ESG366 Gas Cooktop Logo
255 people viewed this question
Top Dacor Cooktops Experts
Marvin
Marvin
ray gallant
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
