Question about Nintendo 64 Console
How to save a game in a game pak n64
Can somebody tell me how to save my Pokemon Blue game into a game pak n64
  • sugarchuy Jan 08, 2009
    when I turn on my n64 with the pokemon transfer pak, it tells me:
    This game has not been saved at a pokemon center,
    How do you save it in a Pokemon Center?
    Scholar:
  • 111 Answers
It is impossible to do so - The only thing you can save is your pokemon/items to pokemon stadium 1 or 2 via the transfer pack
Posted on Jan 08, 2009
  • 132 Answers
You dont actually save it to the gamepak (n64 memory card) it gets saved to the n64 cartridge via a transfer pack that plugs into where the memory goes into the controller then you can import your save with pokemon stadium into the n64 gamepack.
  • Derek Powers
    Derek Powers Jan 08, 2009
    In order to save at a pokemon center, you must go through about the frst ten minutes of the game and go through the path above town to the next town and youll see a building with "PC" on it go inside and talk to the lady at the counter upstairs and she'll save your game!
Pokemon stadium said that i need pak but i have one
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Jan 02, 2013 | Nintendo 64 Console
Pokemon Stadium won't read my Pokemon Yellow
Well it means that the game pack was not made to work on this console at the time it is not companle with Pokemon yellow so you could try and see if it will work on a wii or wii u console. If it works with the game boy advance sp then that's fine for that system then not for the N64 console sorry Pokemon stadium 2 was not made at that time.
Feb 02, 2012 | Nintendo 64 Console
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    Nintendo 64 Transfer Pak...
    Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
    Jan 27, 2009 | Nintendo 64 Console
    Nintendo 64 Pokemon Stadium Transfer Pak Error
    Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
    Jan 26, 2009 | Nintendo 64 Console
    Pokemon stadium, and transfer pak
    That is not the problem, I think you turned off the console too quickly, i.e; before it was done saving.
    Jan 08, 2009 | Nintendo 64 Console
    Kirby 64 won't hold a save file
    The battery inside the game pak has died, thus, it can no longer hold a save.
    Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
    Your game should now save. :)
    Nov 22, 2008 | Nintendo 64 Console
    Nintendo 64 expansion pak
    Barb3: The Jumper Pack (JP) is a bypass for the expansion cartridge. You were supposed to turn off the equipment remove the JP and then use the expansion cartridge. Your N64 Ram it's probably gone for good. Is either replace the RAM, which is hard to find or replace the N64. Sorry for that.... SithPitt
    Jul 03, 2007 | Nintendo 64 Console
    Nintendo 64 Console Logo
    407 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
