Hard disk not found on Dell
I tried to install XP on my Dell inspirion which has come with vista pre loaded. I booted with the XP cd and at the installation screen, there was an error that says" there is no harddisk to install the os, please connect to the system...." something like this.  how to solve this. when my laptop has 160 gb hdd why is it not showing?
  • mailtovamsid Jan 08, 2009
    Thanks a lot !
    But i did the same thing with my lenova laptop, which was having vista. I was able to install xp by formatting the vista. But with dell, it doesn't show hardisk .
    Is it possible to make harddisk invisible.
    As of my knowledge when we try to install a lower version of os on higher version, we first select the drive and then the error comes" cannot install, the version is lowerr ......"
  • mailtovamsid Jan 10, 2009
    Thanks a lot, it worked for me after enabling AHCI in SATA Bios.
    Sergeant:
  • 431 Answers
Actually you cant install operating system. first u have to install lower version and then install higher version of os. install original operating system dont use pirated version
Posted on Jan 08, 2009
I want to change my pre-loaded windows vista on my dell inspiron 1526 to windows xp.
USE WINXP 'S BOOTABLE DISK ,GOTO BIOS ,SET YOUR BOOTING PREFERENCE TO DVD/CD THE SAVE USING "F10" PUT WINDOWS XP BOOTABLE DISK & FORMAT YOUR SYSTEM & LOAD WINDOWS XP.
Feb 14, 2011 | Computers & Internet
Windows 98 on dell inspirion d600 install problem
Installing Windows 98, is you need a start-up disk (floppy disk) first before you can use the Windows 98 cd. The start-up disk will perform the partitioning and formatting of the HD...doing this, you have to boot from floppy drive first---after partitioning and formatting, you have change again the boot sequence to boot from cd then you can start the installation of Windows 98.
Jun 07, 2010 | Dell (6T980-A01) CD-ROM Drive
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
here si the link for lastest nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Disk drive not found
It sounds like the hard drive went bad. Can you see the hard drive in the bios at all? When you try and boot the computer does it say drive not found? Try booting from the vista cd and see if you can start a new installation. If you can do the intallation the drive is ok. If not the hard drive is bad.
Jun 24, 2008 | Dell Dimension C521 PC Desktop
While installing xp in vista machine no hard disk found
this is because you cannot downgrade from vista to xp on the machine in which vista has been preloaded
May 27, 2008 | Microsoft Windows 2000 Professional for PC
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
Trying to downgrade to Xp
Sounds like you need to boot from the disk.Put the windows XP disk in the cd rom turn the computer off then turn it back on.The computer should see the disk and boot from it.Follow the prompts.You cannot downgrade if you are trying to run the installer after you computer has already booted,but you can load the operating system if the computer BOOTS from the XP disk.
Nov 15, 2007 | HP Compaq nx6310 Notebook
No 3d acceleration in Vista on ATI 7500
Well, I'm amazed a C640 runs Vista at all. There's no reason to buy a new hard drive, except for the novenlty of having one loaded with Vista on a C640. It's a great laptop, and runs Windows XP PRo perfectly well. If you have one od the Dell XP install disks, just boot from it, and whenever it finds the vista install, hit excape, then at the next screen hit "D" to delete the partition, then choose "quick format", and load the Operation system. If you need an install disk,let me know. Good luck
Sep 24, 2007 | Dell Latitude C640 Notebook
How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Aug 19, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
