Clean head clogged
Have been clean & deepclean & testprint was cann't solved this problem.
what can i do for this head without replace new.
    Sergeant:
  • 221 Answers
Its not a 100% successful option as there is not a single solution that will clean the head 100% but removing the head and cleaning and keeping the lower part that is from where the ink comes out from the head in a isoprophyl for near to 2 -3 hours.solved the issue for many users but they get the same problem return in next month or two.also check out if the head is severly jammed or clogged going for a new head is much better choise.
Posted on Jan 08, 2009
HP Deskjet 6940 InkJet Printer, white lines across
do a clean - goto printer properties - should see tools
there you can choose to do a clean or deepclean
also try a head alignment on the maintenance section
Jul 15, 2014 | HP Deskjet 6940 InkJet Printer
My prints have "lines" across
Hey!Its most likely that the print head is faulty and needs to be replaced,but it is a expensive spare and it will be cheaper buying a new machine,But that's just me!!Good Luck!
Dec 07, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
I have a clogged Printer Head. Only blue works. Having the printer clean itself doesn't solve the Problem.All ink cartridges are new and full. Is it possible to clean the Ink head or do I have to buy a new...
If your printheads are dried out you will need to replace the printhead. If the printhead is built into the printer it is time to replace the printer or contact Brother directly to see if you can get a replacement printhead for this model.
May 28, 2010 | Brother MFC 3100C All-In-One InkJet...
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer does not print a proper testprint only two or three colors printing. printhead may be damaged cleaned the printhead several times. and try to make testprints but no result.
You have an interesting printer ! I have two of them. Same problem. Basically to use ink refills one must have a chip reset utility. The cartridges are filled from the bottom and consequently leak if not sealed properly. The only solution is to use the blue grey plugs that come with some refill kits- Dell Refill kits have them - but only give you three. The next best is to use black electrical tape heated with a lighter then applied after the fill. What appears to happen is that the ink indicator may say there is ink but the cartridge is actually dry. Additionally I have found some new cartridges seem to have a vent problem - what happens is a vaccuum is created in the cartridge on head cleaning and a color will print, then not print , then the next one will do the same. Some brand new cartridges have chips also that the printer does not recognize. The solution is to use a chip reset tool and the old chip from the empty cartridge on the new one. There is a software called SSC Service Utility that works for deep cleaning and also resetting the ink pad counter - it will stop printing if the pad counter runs out. Basically if it refuses a nozzle check print - it is not getting ink or has no ink left.
Oct 25, 2009 | Epson Stylus Photo R220 InkJet Printer
Video heads clogged - don't get cleaned with cleaning cassette
This needs to be solved at the shop if your product is under warranty.
ESLE
If you are adept at opening gadgets do this
Get a bottle carbon tetra chloride
Dip an end of ear buds and clean the heads without touching any plastic parts. Carbon tetra choloride dissolves plastic. The head look like a small "_" on the cylinder. There will be 2 of them
Babdi
Apr 19, 2009 | JVC GY-DV5000U Mini DV Digital Camcorder
The blue colour dosn't print.
They make kits you can buy in a store for refilling ink. Lots of these kits come with head cleaner.
Jan 07, 2009 | Office Equipment & Supplies
Will not print
Did you do a testprinting after cleaning? Do you have all blocks in bk, c, m and y?
Sep 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
55 people viewed this question
jasbo
jasbo
