Question about LG 52SX4D 52" HDTV
Lg dlp 52sx4d color blue/green and picture approx half to right
Tv picture is blue green color and has shifted to right half of screen.
unit is 3 years old with no previous problems. problem same with all inputs
SOURCE: the lg 52SX4D dlp tv
HAd the same problem with mine, but was under warrenty, they took it to the shop and had to replace the Engine if you need the specific engine name I can look it up, now the bad news if I would have had to pay it would be over a grand for the part alone.
Posted on Apr 08, 2008
SOURCE: lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
Posted on May 24, 2008
electronick
  • 505 Answers
SOURCE: DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Posted on Dec 08, 2008
  • 13 Answers
SOURCE: how to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Posted on Feb 02, 2009
SOURCE: LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Posted on Aug 15, 2009
I replaced the lamp for my LG 52sx4d DLP television. The TV still wont turn on and has a red blinking light where the green lamp indicator should be. How do i get my tv to turn back on!
did you get a Philips lamp check that also make sure all the doors are close also you could trouble shoot more with discount merchant
Sep 13, 2011 | LG 52SX4D 52" HDTV
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Our L.G tv ( model RT-44NA11T)has color problems.
If your TV is not DLP, replace STK ICs convergence.will have part # ON THEM . Projection has 3 tubes a red/ a blue and a green TUBE ---DLP has 1 Lamp.
Sep 18, 2009 | LG Televison & Video
Only blue and green colors??
Go into your tv settings and check the colour/display section, you can also try the auto adjust to see if that solves the problem
Apr 13, 2009 | LG 52SX4D 52" HDTV
Ic chips?? light engine??
the color wheel has gone out. good luck finding a new one. I just had to have my whole unit replaced because parts could not be located.
Jan 31, 2008 | LG 52SX4D 52" HDTV
Green as a frog!!
ya take frog out lol jk did u cheak ic chips the cables mixed up ?
Help
Could be video processing or the light engine. A servicer would have to determine the issue though
Sep 20, 2006 | LG 52SX4D 52" HDTV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
143 people viewed this question
Computer Repairing
Computer Repairing
