Haier RRTG18PABB (207 cu ft) Refrigerator Logo
Posted on Nov 20, 2012
How to drain the tray under the bottom of the RRTG18PABB
1 Related Answer
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Dec 05, 2012
SOURCE: RRTG18PABB HAIER LEAKING WATER FROM FREEZER TO FRIDGE PORTION
Make sure it is not the fill tube from the ice maker first. Yes I would think ice or sludge is blocking the defrost drain and causing water to flow into freezer and then to the floor. Here is more about leaking refrigerators=> Leaking Refrigerators
Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
How to Fix Fridge Water Leak
My Electrolux fridge is collecting water under the trays. No visible drain.
Every fridge has a drain usually on the back wall bottom left inside the fridge; just above the compressor.
Without a drian there is no where for the condensation to go except under the drawers on under the food trays.
It does not look like a drain but it is there.
Some Electrolux refrigerators have a visible drain hole on the rear wall or behind the wall's access panel. In this case, you can flush the hole with hot water to dispel the blockage.
tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 • Refrigerators
2helpful
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
1helpful
Ice maker is le
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Good luck......
4helpful
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
4helpful
4answers
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
1helpful
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
