Question about Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA
REMOVE CHUCK I HAVE A 925 DEWALT HAMMER DRILL AND CAN'T REMOVE CHUCK HEAD ' NO SCREW ;
  • 21 Answers
The only way is with a special chuk key , and is not available to customers, if you still want to replace by yourself, you can by the whole gear case cover assemble that cames with the new chuck, but is is expensive.
Posted on Sep 25, 2009
    Novelist:
  • 178 Answers
Remove the REVERSE-THREAD screw at the bottom of the chuck(if it has one). Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Posted on Nov 26, 2010
4 Suggested Answers
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
  • 13 Answers
SOURCE: how do you remove the chuck from a Dewalt
THAT MY FREIND IS A REAL PAIN IN THE ***!!! YOU FIRST HAVE TO REMOVE THE CHUCK SCREW WICH IS A LEFT HAND THREAD. THEN INSTALL AN ALLEN WRENCH IN THE END OF IT! THE SHORT END OF THE ALLEN WRENCH!! ( USE THE BIGGEST ONE THAT WILL FIT IN THE DRILL))) NOW LAY THE TOOL ON ITS SIDE AND WITH A DEAD BLOW HAMMER OR BALL PEEN HAMMER HIT THE ALLEN WRENCH LIKE YOU GOT A SET!!! THE IDEA IS TO SHOCK THE CHUCK OFF OF IT WICH UNSCREWS STANDARD THREAD, YOU ARE BASICALLY TRYING TO UNSCREW THE CHUCK BUT WITH HAMMER DRILLS, THE CHUCKS ARE ON REALLY TIGHT, IT IS POSSIBLE THAT YOU WILL MESS UP THE GEARS OF THE HAMMER DRILL.!!!! I HAVE DONE IT BEFORE, IF YOUR LUCKY CALL YOUR LOCAL SERVICE CENTER AND ASK THEM HOW THEY DO IT OR SEND IT TO A FACTORY SERVICE CENTER THEY SHOULD BE ABLE TO WALK YOU THROUGH IT! WHATEVER YOU DO! DO NOT USE THE LOCK BUTTON ON THE SIDE OF IT, IT WILL BREAK IF YOU TRY TO USE IT LOCK THE SPINDLE. MOST OF THE TIMES THEY WILL JUST SHEAR OFF! THANKS JIMS TOOL SERVICE
Posted on Feb 02, 2011
emissionwiz
  • 77194 Answers
SOURCE: Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Posted on Feb 16, 2012
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Nov 15, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Remove c keyless chuck from 18v dewalt drill
There is no loctite on the chuck threads, only blue loctite on the reverse screw. This is how I remove chucks.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jun 15, 2010 | Dewalt 18v Battery Hammer Drill Dcd950...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
How do you remove the chuck from a dewalt 925 XRP hammer drill
Open the chuck fully and look down the centre and you will see a philips head for a screw the thread on this is opposite so instead of undoing to the left, undo to the right. There is will be a spot of threadlock on the screw so may be a tad tough the first turn, Once removed unscrew the chuck from the spindle of the drill, you may need a good pair of grips or a vice for this as some get very well stuck on! I hope this helps
Oct 08, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
How do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Oct 01, 2009 | Dewalt Drills
How to change a nozzel
to change the chuck you must remove the screw inside chuck by turning clockwise as it is cross threaded then place an allen key in chuck tighten and hit several times with hammer till chuck lossens
Feb 23, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA Logo
334 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
