Question about EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard
Pc bios battery faulty
The battery on the M/B does not work even a new battery would not work I need to enter bios to keep date right, what is the best I can do.?
M/B NFORCE4-939 using Win xp64 only 3 year old.
Henry Jozefowski
  • Christoffer Petterson May 11, 2010
    have you tryed cleaning the connecting surface where the batteery sits?
  • 85 Answers
Hi there check board for bios reset normally jumpers that have to be shorted,you must also disconnect power plugs from sockets normally 24 pin and 4 pin for about minute,reset bios on board for few seconds
put bios back as it was reconnect power plugs,reboot to get into bios on screen normally hit DEL button or what your screen tells you ,enter cmocs screen change date etc and check all devices are detected then save when your finished and should boot on its own
Posted on Jan 08, 2009
What is "the firmware has detected that a CMOS checksum error occurred.Press the Enter key to continue. The firmware has detected that the system date/time has not been set." What is this error.
I assume that you entered the BIOS after replacing the battery and set the date and time? If you cannot get to the BIOS after receiving this message, it usually means that the BIOS has become corrupted, either by failure or by virus. You may be able to reflash it if you can download a bios update from the manufacturer.
Dec 24, 2014 | Computers & Internet
Sir, please my asus a7v400-mx time and date get missing everytime i boot my pc even when i replace a new battery. please help
HAVE YOU DONE SETUP.?GO IN TO BIOS SET RIGHT TIME.
PUSH F10 FOR SAVE.NOW PUSH THE ENTER-TANGENT
THE COMPUTER WILL RESTART WITH THE SET TIME.
Aug 13, 2013 | ASUS A7V400-MX Motherboard
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
Time and date keeps reseting even though I changed CMOS battery, battery is ok, tried it on another PC
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
hope it helps
Apr 27, 2012 | HP Compaq dc7600 Small Form Factor PC...
My system time and date is not set
Go into the BIOS settings then to the Date and Time and set the Date and Time, Save the settings and Exit.
IWhen you boot up later and the Date and Time is incorrect then the BIOS battery is flat and a new replacement battery is needed. The BIOS battery keeps the laptop's configuration plus the Date and Time settings unless the battery is flat.
Apr 16, 2012 | Dell Inspirion Computers & Internet
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
How do I change the battery on my PC?
Yes you need to install a new BIOS battery. The old BIOS battery is flat and it cannot keep (store) the BIOS setting. Most motherboards use a coin size lithium 3 volt battery type CR2032 button battery.
Check the type of BIOS battery your motherboard uses.
When you replace the BIOS battery, go into the BIOS and set the Date and Time.
Nov 17, 2011 | Computers & Internet
I have a Gateway laptop model no. M622-UCX which continues to prompt for the system date configuration in cmos setup during start. It also cannot remember the date and time I entered several times and...
When a laptop/computer prompts for a BIOS date and Time setting every time you boot up, this indicates the BIOS battey is flat or nearly flat. This BIOS battery needs to be replaced and the BIOS Date and Time setting needs to be configured etc.
Mar 14, 2010 | Gateway Computers & Internet
Laptop will not keep current date/time
The BIOS battery is nearly flat and this is causing the time to drift.
Replace the BIOS battery with a new one, then you will need go into the BIOS configuration to set the date and time.
Apr 30, 2009 | Sony VAIO Notebook
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard Logo
110 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
