How to find binomial cdf and pdf on calculator
SOURCE: I have a TI-86 calculator and i'm trying to put
Data type maybe incorrect, program may be archived.
Hope it helps.
SOURCE: I was told that, to do binomial distributions on a
Sorry, but you information is wrong, to find the binomial distribution use the PROB menu not the STAT menu. Its name is randBi
[2nd][MATH][F2:PROB] scroll right.
Hope it helps.
SOURCE: I totally forgot how to do binomial pdf can you
Press the yellow [2nd] key then [VARS] (DISTR) to access the distributions. Scroll Up or down to see 0:binompdf( . Press 0 |ENTER|. The command echoes on the screen as binompdf(. Complete the command by entering the number of trials, the probability of success, and the value expected. Number of trials, and the value expected are integers.
You can also run the command giving it a sequence of expected values. In that case the sequence of expected values must be enclosed in curly brackets
Hope it helps.
binompdf ( number of trials, p, { expec_value1, expec_value2, ...} ) [ENTER]
SOURCE: Missing binompdf and cdf on my ti-89
Do you have the Stats/List-Editor app loaded? If not, you can download it from http://education.ti.com
You can also try StatLite, available from http://www.ticalc.org
Testimonial: "Thank you so much!! ONE more thing, do i need a specific usb cable or can i use any usb a to usb mini A cable?"
