Question about Apple iPod touch
On my ITouch screen there's a picture of a battery, plug-in cord, and a lightning bolt when I try to recharge my device what is wrong?
    Scholar:
  • 120 Answers
Oh, does it tell you to connect to a power source or something? I had the same problem with my iPod nano 4th Generation. What you need to do (according to Apple) is just plug it in for about half an hour max and it comes back. The computer surely won't detect it as there is no power even to connect to the computer. Then it will connect once it has enough power to do so.
I tried and it worked.
Posted on Jan 08, 2009
What does a Nuvii 55 LM screen green icon with lightning bolt mean ?
The lightning bolt indicates that the battery is being charged. Remove the unit from the charger and the lightning bolt will go away.
Feb 07, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
Why is my iphone not charging?
This means it's not getting a charge. I've just experienced this problem myself. I followed instructions online regarding cleaning lint from the charging port of the phone. Still no charge. I bought a charging cable that came with a car charger made by Belkin, this worked in the car, also allowed me to charge the phone from the pc, but wouldn't charge from the original plug. So I purchased an original Apple branded lightning cable today and it works. At last. So it turns out that my cable was faulty and another branded cable would not work with the Apple plug. So you need to try a known working Apple cable and plug and failing that clean out the port on the phone as lint is a common problem.
Jan 02, 2015 | Apple iPhone 5S
I tried to restore my ipod back to its factory settings... It cut off and back on and now it acts as if its loading. It said it would take an hour but its going on 2days now. Then when I plug it up it...
If you try a different power cord and still get the low battery symbol (plug and lightning bolt) after leaving it sitting for a while, then you may need a new battery. After replacing the battery, if you still need to, you should be able to restore your ipod without a problem. Hope this helps!
Dec 15, 2010 | Apple iPod touch
The screen is freezing, and then the battery indicator has a lightning bolt looking thing through it. bad battery? reset?
The lightning bolt means the battery is being charged. Remove the charger and you will see that go away. As far as freezing, you might have a bad touchscreen. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Sep 01, 2010 | Garmin Nuvi 660 GPS Receiver
Typrice never helped with my flash problem, I need help.
Is your battery fully charged? It's not an old battery on its last legs, is it?
Dec 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Presario C500 Wont turn on
sounds like the d/c adapter was either installed backward or the wrong part was installed, also check the connector on the new power cord to the laptop, you may have gotton an incorrect power cord. because what you describe is the internal power system is shorting out. take battery out and check it with a volt meter , if the is no volts/or negative volts on the battery ,it has gotten internaly reversed , and needs replacement.
Mar 25, 2009 | HP Compaq Presario C500t Notebook
ITouch screen locked and showing iTunes logo
try to plug the itouch into a charger/computer.
its probably dead.
Feb 25, 2009 | Apple iPod touch
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
New battery on used phone won't charge
The battery might be bad you can go and have someone check the battery at any electronic store with a voltage meter.
Apr 22, 2008 | Palm Treo 700w Smartphone
Battery doesn't charge
Is that the original power cord for that? Or was that one bought aftermarket, some aftermarket chargers will only power your laptop and not charge.
Mar 12, 2008 | HP Compaq Presario V2000 Notebook
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
