Question about Panasonic AG-DVC60 Mini DV Digital Camcorder
Que es wornings psd ng
Amigos el monitor de mi camara panasonic AG DVC60 vibra muchisimo y parece como si tubiera puesto toda la ganancia o toda la avertura del iris pero no es asi y dice WORNING PSD NG Como puedo areglarlo hechenme la mano no puedo solucionarlo,gracias por sus atenciones
4 Suggested Answers
premtech
  • 934 Answers
SOURCE: PROBLEMAS DE CONVERGENCIA
Translating what you said you can't get the red to move.. This means that the two convergence amps have failed and must be replaced.. Your set takes two STK392-110 Ic and after replacing them also check all of the 2.2 ohm resistors out in front of them for any change in value of resistance.
Bill
Traduciendo lo que usted me dijo entienda que usted no puede conseguir el rojo para moverse. Esto significa que dos la convergencia amperios ha fallado. Su toma dos Sanyo STK392-110 Ics de la televisión y después de substituirlos también comprueba y substituye los resistiors de 2.2 ohmios que pudieron haber cambiado en valor. Cuenta Bill
Posted on Feb 03, 2008
  • 15 Answers
SOURCE: videocamara en japones: quien puede publicar el manual de instruc
Also refered to as nv-gs50e or nv-gs70e. Go to http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders#Anchor_13 it will be the third driver from the BOTTOM. This model has been discontinued so support for later windows editions are not likely. Windows 2000 is the last version you can always run your compatabilty mode with 2000 for optimum preformance.
PAL Mini-DV Cameras/recorder
NV-GS50E
Posted on Feb 05, 2009
SOURCE: buongiorno.la macchina in questione
ciao!per difetto di linea di panasonic ag dp800,ho avuto steso problemo,100% sono tre filtri di condensatore elektrolitici,nella scheda video 3700[c 03/c06/c09] e sicuro dopo sostituire tutto ok,o provato io alcuni giorni fa.piu meglio e per sostituire tutti condensatori delle schede video.piu info nell mio email[avstudiosda@yahoo.com]
Posted on May 17, 2011
Donde se ubica el claxon
El claxon esta debajo de la base de la bateria ,pero por debajo de la lata del guardafango izquierdo, o sea casi atras de la pantalla de la luz , de todas forma si no le suena lo mas provable es que el problema este en el timon ,porque lleva una cinta enrollada como una cuerda de reloj que se parten,en el explorer 1999 es de 7 cables por el acelerador de mano o de velocidad crusero ,si no te funciona esto tampoco sacar el timon con toda confiansa que es eso . escribe para saber si lo solucionaste con mi ayuda . Ingeniero Marrero
Nov 16, 2012 | 1996 Ford Explorer
Nesesito cidigos para una tv orion
Hola CharlyCarraz! Mi nombre es Kimberly y soy representante de DISH Network. Con mucho gusto le puedo ayudar con la informacion que necesita. Ciertos codigos que pueden ser integrados a su control para que pueda controlar ciertas funciones con su televisor son los siguientes: 720, 694, 500 y 621. El proceso a programar el control es el siguiente: Oprima el boton de TV localizado en la parte de arriva del control hasta que los demas botnones se iluminen en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero (#). Por ejemplo 720#. El boton de TV en la parte de arriba deberia de iluminarce 3 veces, una vez esto suceda pueda intentar usar su control con la TV. No podemos prometer que todas las funciones trabajen pero lo basico como prender o apagar la TV y el volumen deberia funcionar. Tambien existe este link http://cot.ag/fSMjSH aqui puede encontrar todas la instrucciones en como programar el control y los codigos que tenemos disponibles. Puede contactarme directamente si necesita ayuda a kimberly.escobar@dishnetwork.com Gracias por su tiempo y espero esto sirva de ayuda.
DISH Network
Kimberly Escobar
Oct 27, 2011 | DISH Network IR Remote Control
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Como puedo instalar los drivers de la camara web. Cuando conecto la webcam, la pc me PIDE que Inserte el CD pero me dice que no encuentra los archivos . Puedo descargarlos de algun lado? es una GE 98650,...
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
Dec 28, 2009 | GE EasyCam Webcam
Mi problema es con una laptop Toshiba Satelite L300 es que me detecta vbarias senales de internet inhalambrica que se encuentran donde vivo pero no me deja conectarme me sale que tiene coneccion limitada...
Sabes que es encrypcion WEP o WPA?
Necetitas la llave correcta par decodificar un señal WIFI.
Parece que todos alrededor de ti han puesto en uso su encrypcion en el "router". Gratis no hay. No tienes subscripcion con un ISP (Internet Service Provider)? Regresa donde tu prima y pregunta si ella anda cual conexion con cual codigo :)
Mar 04, 2009 | Mozilla Firefox
NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
gracias
indira
Jan 12, 2009 | General Electric A835 Digital Camera
Cuenta revoluciones
Hola amigo, a mi me paso lo mismo y creo que a muchisimos rpopietarios de charades les sucede. EL problema està en la plaqueta detras del instrumento. hay un integrado que es casi imposible hallar. Yo solucione el tema poniendo otro instrumento usado de otro coche. No se si el tuyo es 3 o 4 cyl. Cuentavueltas standard de 3cyl no vienen asi que hay que reparar si o si el existente. si es de 4 es mas facil porque compras uno cualquiera y lo colocas. Suerte.
Jul 29, 2008 | 1992 Daihatsu Charade
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
PROBLEM CON SOUND AND TV
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
Sep 07, 2007 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Panasonic AG-DVC60 Mini DV Digital Camcorder Logo
62 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
