Question about Mitsubishi VS-55705 55" Rear Projection Television
Older rear projection tv
I have an older rear projection Mitsubishi tv. I have sound, but every once in awhile the picture would just go out. Sometimes it will come right back on after a few mintues, then there have been times I cut it off for awhile and then it will come back on. There are times when I've had to leave it off for a whole day and it would stay on for a month or more. Is it a fuse or connection wire loose?
    Scholar:
  • 52 Answers
I have the identical model, purchased in early 2000. I had the same issue, and called Mitsubishi service. Turns out there is a known problem with the video power supply. Mine was under warranty when it was repaired (in 2002), but by now yours probably is not. I recall the repair guy did the fix with no parts, just a soldering iron. If you're handy, you can probably get the details from MITS service and try the repair yourself. If not, I suggest the repairman route.
Posted on May 31, 2007
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
Video games projection on a Mitsubishi WS-65869
1,2 error code means NO ERROR FOUND. The set is older and may not be compatible with this set---what type of connection is being used and to which rear input?
Dec 16, 2012 | Mitsubishi WS-65869 65" Rear Projection...
The picture is dark or not as bright as it use to be. Tried settings for billant/brignt but no help
It sounds like your lamp is starting to dim.This is normal after so much usage.Mitsubishi 915P020010 Lamp is the one you need and you can find this @ discount-merchant.com
May 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Older rear projection 63 inch Mitsub. A brown block
Ur convergence is dead.Must replaced 2 Convergencce ICS,and some or all it resistors.Can u solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have no picture. The screen will not come on. When I attempt to turn it on, the TV makes a sputtering sound coming from the bottom right (if you are facing the tv) speaker area. It sounds as though it's...
SOUNDS LIKE YOUR LAMP IS OUT. AS FAR AS WHAT MITSUBISHI IS DOING THEIR NEWER DLP'S THEY REDUCED THE COST OF THE LAMPS TO $99. BUT ON THESE OLDER ONES THEY ARE DOING NOTHING.
Aug 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Ws-65809 no high voltage
HI INMARK66-THATS FUNNY I HAVE THE SAME MODEL BUT MY PICTURE TUBS ARE ALL GLOWING I HAVE SOUND BUT NO PICTURE EITHER.????DO U STILL HAVE PROBLEMS WITH THIS TV???IF NOT LET ME KNOW WHAT U DID TO IT???LOOKS LIKE U POSTED THIS AWHILE AGO??THANKS GLENN
Jun 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
