Question about D-Link Airspot (DSA-3200) Router (DSA3200)
D-Link DSA-3200 Gateway/Router and Access Points
I been having intermittent wireless connections when like 12 people are connected to the access point, which is hard wired to the DSA-3200 Gateway/Router which has 2 public lan ports and 2 private lan ports. I use the Public lan port. I am using a static ip address on the router, to the cable modem on the wan port.
    Scholar:
  • 31 Answers
Please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
I can't enter the web from 192.168.1.1 or 192.168.1.2 how i can enter web setting AP senao 8610S? what sould i do?
Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
I've forgotten the username and password for my router. The router I have is the DSA-3200. Airport wireless G public/private gateway. Is there any way I can reset the password to default
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 29, 2010 | D-Link AirSpot DSA-3200 (F56772) Firewall
Gateway not pinging from dwl 3200 ap . AP=192.168.4.250/24 in the same subnet, gateway=192.168.4.1 , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
How do I reset an Intel Wireless Gateway - Product Code: WLGW2011BAK to factory default. And, then what is the IP address to regain access?
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Aug 31, 2009 | Intel Wireless Gateway (WLGW2011BAK)
Problem connecting adapter with wireless router
Open router site by giving IP. http://192.168.1.1 in your Browser
Config. your router from setup the enable network router will attain gateway IP Auto. Save the changes. your internet will be connected.
If your problem is solved donot forget to rate.
Thanks.
Jul 20, 2009 | D-Link DWL-G820 802.11g/b Wireless Gaming...
Wireless signal intermittent
First make sure you have the latest update for your bios and wireless device, your os is probably non preload so clean any access connections utility provided by ibm, rather than using the ibm thinkvantage access connection make sure to use the windows own utility to control the wireless device
Feb 11, 2009 | IBM ThinkPad T43 Notebook
Belikin adapters and a wireless gateway
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
Jul 08, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Can't get it to talk to my LAN in ad hoc mode
Is the AP connected to the router using a ethernet cable? Are you having similar issues when you connect wirelessly to the wireless router?
Feb 11, 2007 | D-Link AirPro DWL-810+ 802.11b...
D-Link Airspot (DSA-3200) Router (DSA3200) Logo
81 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
