Every time i start my pc it goes to bios screen
Every time i switch my pc on it goes to bios settings. The time & all the settings are gone back to factory settings. how can i solve this. i am not a technical person. if some one can give me a step by step guide to see what the problem is it will be much appriciated
thx
  • 416 Answers
1. open the PC up.(make sure the power is switched off)
2. check for a small coin shaped battery on the motherboard.
3. remove the battery.
4. buy new one & replace.
most likely the battery is dead.
Posted on Jan 08, 2009
  • 22 Answers
What is your operating system?
My date is not getting set in bios
Change the CMOS battery.
If you had taken the time to post the computer manufacturer name, and model number; I would know what motherboard we're dealing with, and what type of CMOS battery it uses.
Generally the battery is a CR2032.
A type of watch battery.
Positive ( + ) side ALWAYS goes UP
Post back in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | Computers & Internet
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
When i switch on my pc ,the hard disk light starts glowing but after some time the light goes off..nothing appears on screen ,the monitor never goes on plz help me sort out ds prob.
The problem would be solved with 80-97% (aprx) accuracy if you replace the CMOS battery and re-set the BIOS replacing/switching the CMOS jumper. 10-15% times this happens due to RAM problem. 5-10% chances for motherboard problem.
Jun 05, 2010 | Samsung Computers & Internet
Computer has been working fine. Now all of a
When system boots press the key to get into BIOS. Usually it is 'Del' Key. Once you get into BIOS, if not asking a password, get into admin menu and set the password option disabled.
If asking for a password while you get in to BIOS and you dont know the password, the only option is to reset the BIOS.
To reset BIOS u've to remove the back cover and remove and re-insert the CMOS battery while the laptop is powered off. After that, power on the laptop and set the bios to normal setting, especially the time. This wont harm any of your data.
Please come back and vote for me if this finds helpful for you. Thnx
Mar 28, 2010 | Computers & Internet
Screen wont come on flahses logo in middle and on left side
In your case it may not see teh hard disk ..or ..teh battery (insternal one for bios ) ..is gone ..and it asks you to press F1 to get to settings and see whats wrong ..
press the key indicated and see what it does..if it goes to bios ..just save changes with F10 and boot to bios ..set the time and date in windows ..Its easier ..
This may repeat if the battery is empty ..(I repeat i'm talking about bios battery .
Jan 18, 2010 | Toshiba Satellite M45-S331 Notebook
Won't start up
Hi there.
If the beep is a short beep then there is nothing wrong with the PC, just enter the bios utility, set the date and time, save the changes and exit the bios.
The computer will restart and should boot straight through to windows.
Please post back if you need anymore help or advice.
Good luck and thanks for using FixYa!!
May 24, 2009 | IBM ThinkPad T21 Notebook
I press power to start it up it beeps at me and screen is blank
Disconnecy every item plugged in apart from the usual like keyboard, mouse and monitor. Any USBs should be removed. If it doesnt do it then, it is likely too high power draw from the USB devices. Get a powered USB hub.
This is a common fault with an older lower powered power supply. This typically raises its head when another hard drive is fitted and the power pull is too high on boot up.
I would also recommend you back up any important data as this can also be a hard drive fault waiting to happen.
Apr 10, 2009 | HP Pavilion a705w PC Desktop
Computer turns on but does not boot windows, no bios screen
As you seem to not be a total novice with electronics, I would suggest you try unplugging everything with in the computer apart from the big plastic (Molex) connector from the power supply.
So unplug hard drive, cd/dvd drive, all pci cards, monitor and any memory.
PLEASE MAKE SURE THE PC IS OFF WHEN DOING THIS AND TURN OFF AT THE MAINS>
Turn your pc back on, you will hear a beep, nothing to worry about, its because you have nothing connected yet.
One by one start to connect the components back in the unit.
All this is doing is fault finding to see if its hardware related.
might be worth connecting your hard drive 1 at a time if you have more than 1 but the one with your operating system needs to go in first.
Add the ram 1 stick at a time aswell incase it the memory thats gone faulty.
Just remember to be careful with static if you can..
Check your graphics card aswell if you have added one:
Everything that I have read so far points to a graphics card failure..
http://en.wikipedia.org/wiki/Power-on_self-test
Jan 20, 2009 | Dell Dimension 2400 PC Desktop
What model is your PC ? It may be that your CMOS battery needs to be replaced. Its a little battery on the motherboard, usually round like a size of a nickel. On laptops its called an RTC battery. Once you replace that try again.
Jan 08, 2009 | Computers & Internet
Motherboard
There is normally a system tamper reset within the bios settings somewhere. Alternatively try to reset by the JBAT1 terminal by putting jumper from pins 1-2 to pins 2-3 then back again and restart pc. You will have to set the time again and make sure the HDD is detected in standard bios settings and re start.
Jan 16, 2007 | ASUS A7N266-VM Motherboard
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
