Question about Samsung HL-R4667W Rear Projection Television
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is either green or blue, bouncing
  • 133 Answers
Needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Posted on Jan 08, 2009
Picture ok with a 6 inches blue vertical line from top to botton
For a five or 7 inch band we have a fix. Six is a big problem. A vertical band is either a sync condition requiring an adjustment of one or more pots on the circuit board. Usually the condition is Horizontal and rarely up and down the screen. LED is generally very reliable and two of 3 colors within the diode in your case (one red and one green) are not working. If this TV is in Warranty, replace it as you cannot fix this yourself.
Jan 10, 2014 | Samsung UN55EH6000 55" Class LED HDTV...
My dlp hl-s4266w had developed a 10 " wide vertical darker area than the rest of the sceen
Usually this will be on top or either side and the problem is the optical light engine is damaged from heat----seen about a dozen.
Dec 04, 2012 | Samsung HL-S4266W 42" HDTV
I have a samsung 50" DLP tv and it starts having v-hold issues when certain bright colors are being projected.....what can I do to remediate or am I screwed
sounds like your color wheel is going bad. usually the fix is pretty inexpensive. there isnt a vertical hold on those type of sets.
Jul 02, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
White lines on Samsung DLP
need the modle number to see if there is a service flash or fix/
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R4667W Rear Projection Television Logo
183 people viewed this question
Henry  Thomas
Henry Thomas
