Every time i start my pc it goes to bios
Every time i switch my pc on it goes to bios settings. The time & all the settings are gone back to factory settings. how can i solve this. i am not a technical person. if some one can give me a step by step guide to see what the problem is it will be much appriciated
thx
    Novelist:
  • 176 Answers
What model is your PC ? It may be that your CMOS battery needs to be replaced. Its a little battery on the motherboard, usually round like a size of a nickel. On laptops its called an RTC battery. Once you replace that try again.
Posted on Jan 08, 2009
I have a toshiba A25-S279 and when i turn it on it shows the toshiba logo and after that it says "password".. iv tryed going to factory settings but it wont do anything ..i tryed "0" i tryed f1 and f8,...
trying to do reset the BIOS,
1. Remove the BIOS battery, leave it for 24 hours. Try installing again.
2. Reset the BIOS with the jumper, http://www.youtube.com/results?search_query=clear+bios+toshiba+A25-S279
Good luck
Jun 01, 2014 | Computers & Internet
Factory reset
Most PC's during boot up you can hold the Del key or F2 key to enter the bios. Each bios is different but most have settings that allow you to set the system to the optimum or default (factory default) setting.
However be very careful what you change in the bios.
Record the steps so if something goes wrong you can undo it should the system not run or error out.
Most motherboards have a Cmos (Reset).
This is a jumper with pins 1,2 and 3. The jumper is usually on pins 1 and 2. To reset the Cmos to factory defaults pin the jumper on pins 2 and 3 for 2-3 seconds. (Machine OFF power unplugged!! Before you do this! You have been warned) After 2-3 seconds put the jumper back on pins 1 and 2. Plug the PC power cord up and start the machine. Laptops do not have this. Also note: Cmos is NOT the Bios.
Hope this helps good luck and be careful in the bios.
Mar 31, 2014 | E-Machines eMachines Desktop PC
Date and time wrong on start up
This indicates the BIOS battery is flat and therefore cannot store the correct date and time in the BIOS. You need to install a new BIOS battery and then go into the BIOS setup to set the Date & Time.
Nov 14, 2012 | Advent Clearance 5411 Laptop...
I have acer aspire 5736z which has bios password, and i have tried many times to remove bios battery but password still remain, so please help if there is any way
Remove the CMOS battery (what you call the BIOS battery), then press the power button and hold it for three seconds. Connect the two terminals where the CMOS battery goes (you can do this with any metal device, such as a screwdriver). Place the battery back in, and then start the computer up. The BIOS should now be reset to factory settings.
Jun 21, 2012 | Computers & Internet
My bios password is unknown and i can not access the actual settings. i can however boot into windows.
Normally, Toshiba may have a default password such as "toshiba", try that first.
If not successful, then power down the laptop, remove the battery for about 30-45 minutes, then power back and go into bios, the password should be gone.
It is important to remember that with this method, the bios goes back to factory defaults and the time and date may have to be reset.
It neither do not remove the password, then the bios has it's own battery and would have to be accessed and removed to clear out the password. I do not recommend this option unless you
are knowledgable about disassembling the portion on the unit to get to the battery.
Good Luck
Aug 25, 2011 | Toshiba Satellite L305D-S5974 Laptop
When I switch on the system I am getting the message as "Error 0210: Stuck key 01 Press F1 for set up". What it means...? How to solve this...?
This is something to do with the BIOS setting. You may boot to the BIOS and set it back to factory setting and check if the issue persists. To enter BIOS press F2 key as you restart the computer. Once you boot into the BIOS reset to factory settings.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | Computers & Internet
Want to reformat EeePC900 back to factory settings...tried holding F9 option but its not working...holding it for a very long time only makes the screen black and once I let go it starts up the system...
When your system is start then hold f8 key and bios setting will be appear hear will you change your restore factory setting. Or when your bios setting will not open then hold delete button then it appear.
Nov 07, 2010 | ASUS Eee 900 Notebook
I have a dell dimension with the BIoS locked can you help me
Since you mean the bios password, you can do this. Unplug from the power your desktop. Open the case and locate a small round battery on the motherboard that looks like this:
Eject this battery from its place. Push the power switch a few times (without power cable connected). The system will not boot but the capacitors will discharge. Wait for a couple of minutes. Place the battery back to the original place and start up the pc. The password must be gone. A good idea is to check the rest of the settings by entering the bios settings, or even better to load the preset settings (factory defaults) and make any changes as you wish (boot order, time, date etc). In case of not working post me a reply because on some cases a jumper connection setting is also needed (temporary) but since you don't specify your Dell I don't know your case.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 01, 2010 | Computers & Internet
Every time i start my pc it goes to bios screen
1. open the PC up.(make sure the power is switched off)
2. check for a small coin shaped battery on the motherboard.
3. remove the battery.
4. buy new one & replace.
most likely the battery is dead.
Jan 08, 2009 | Computers & Internet
Motherboard
There is normally a system tamper reset within the bios settings somewhere. Alternatively try to reset by the JBAT1 terminal by putting jumper from pins 1-2 to pins 2-3 then back again and restart pc. You will have to set the time again and make sure the HDD is detected in standard bios settings and re start.
Jan 16, 2007 | ASUS A7N266-VM Motherboard
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
