Question about Samsung LN-T4665F 46 in. LCD Television
46" SAMSUNG IS NOISY AND SOUNDS LIKE A AIRPLANE WHEN TURNED ON
ITS 3 YEARS UKD AND HAD A PICTIRE TUBE REPLACED 30 MONTHS AGO. THE PICTURE SHOWS SOME DISCOLORATION
    Champion:
  • 225 Answers
Most high voltage electronic parts in a tube style television only have a life of 1-3 years. All of your internal parts are due to burn out or fail.
I would give up and sell/give away this tv and buy a new LCD or Plasma version. Repairing and old tube style tv is probably going to cost over 500 dollars. Just put that money to a nice new one instead. I know it sucks to say goodbuy to your old friend, but the era of the tube tv has ended.
Posted on Jan 08, 2009
I have a 46" Sony Bravia. Approx 5 years old. Screen was replaced a couple years ago under Target extended warranty. Now the center of the screen is black. Audio is fine and you can see the picture about 6...
I have a "Home-fix" for you, you should watch this you tube video on how to repair a symptom such as yours even though it is a sanyo tv the fix is pretty much the same for your television and may save you oodles of money!
http://www.youtube.com/watch?v=purk_SyiT44
Good Luck!
Rich Lilja
Nov 17, 2013 | Sony BRAVIA KDL-46S2010 46" LCD TV
I have a Samsung 46 " LCD that is 2.5 years old. We had 3 capacitors replaced about 2 months ago, tv clicked but wouldn't come on.Now we have a new problem. The picture will be dark for awhile and then it...
No,this problems it the T-CON decoders board problems.This board sit right in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 16, 2010 | Televison & Video
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
That certainoy sounds like the color wheel assembly inside of the light engine is bad. The light engine is located here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00674A&search%5Fmodel=HLP4663W Good Luck
Aug 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung LN-T4665F 46 in. LCD Television Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
