Question about RCA P52921 52" Rear Projection Television
60 inch rca dead set
Will not cut on. need help
  • RCA Master
  • 5,138 Answers
2 things cause this high voltage trippler or your flyback transformer.
Posted on Feb 17, 2008
How to program a 60 inch rca tv to a different rca 2 progam remote
Not normally possible because they are not programmable. One remote, one set.
Jul 31, 2017 | RCA Televison & Video
How do I cut an angle of 135
You would cut a 45 from the backside if the face side is to have a 135 degree cut. You will need trim up to the final cut.
Maybe this image will help explain it.
Mar 19, 2015 | Garden
Bogs down while cutting does carb need adj.
Every saw is going to bog down some when cutting. What condition is the blade? I would need more information on what kind of saw it is in order to try and help. Is this gas powered? Wet saw? Wood, concert or steel?
May 15, 2014 | Saws
My brother overlocker blades dont cut anymore and thet dont move either, please help!!!
if the blades don't cut then they need to be replaced,, and for the
blades not moving,, the machine need to be checked..
Apr 19, 2013 | Sewing Machines
I own a cordless Black & Decker 19" rechargeable mulching mower, CMM 1200, 24V. There are days that it starts beautifully, and others where it remains quiet and uncooperative. Temperature seems to...
Mulching mowers are notorious for needing to be cleaned out frequently. The problem usually is the cutting height. The lower it is, the faster it gets clogged up.
Cutting wet grass doesn't help this situation either, it actually makes it clog up much faster.
Set the cutting height to about 3", and wait until the grass is dry before you cut it. This should help with the cuttings buildup.
As a landscaper, I deal with lawnmowers on almost a daily basis, and on cold mornings, the mowers are sluggish and don't want to run well.
If you keep your mower stored in a weather proof building with a consistent temperature and humidity level, there shouldn't be many issues with startup. Start it up and let it idle at half choke before cutting.
I hope this helps you.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Black & Decker Cmm1200 24v 19" Cordless...
WHILE THREADING 4" CONDUIT THE MACHINE WILL NOT
If I remember this machine, you have an adjustable thread cutting head. 4" is a large area for a thread cut, how you can help this is by using lots of oil, and make your cut with the cutting teeth not at the deepest they can go. In other words, cut the full length but cut it shallow at first, then redo the cut a little deeper and so on till you get to the depth that you need.
Joe
Feb 22, 2011 | Ridgid 26092 1224 Threading Machine
I have a 60 inch RCA tv rear projection digital. the picture is like seeing 3 of everything. I have being able to fix this in the past by using the convergence option on the setup menu. but now the...
what it is the tvs like this are mento be serviced every 3 years or so the convergence settings are in the back only user ones are in the settings dont try this yourself though i broke mine lol it will cost 120 pounds tops to fix dont worry its worth it if this has helped please give me thumbs up because people are just taking answers and not voting
Jan 15, 2011 | RCA P60921 60" Rear Projection Television
RCA P52921 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
